heute Nacht hat sich unser MySQL-Server verabschiedet - schuld daran war eine fehlerhafte InnoDB. Jetzt haben wir das Problem, dass das Shop-Frontend nur noch eine weiße Seite zeigt und das Backend fogende Fehlermeldung
The provided CSRF-Token is invalid. If you're sure that the request to path "/backend/Login?file=app&no-cache=1493714177" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in engine/Shopware/Components/CSRFTokenValidator.php on line 108
Stack trace:
#0 [internal function]: Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#2 engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#3 engine/Library/Enlight/Controller/Action.php(143): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#4 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#5 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#6 engine/Shopware/Kernel.php(180): Enlight_Controller_Front->dispatch()
#7 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#11 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#12 {main}
Cache manuell gelöscht und auch über SSH. Beim Versuch das Template neu zu cachen (über SSH Console) kommt folgende Fehlermeldung:
[Doctrine\DBAL\DBALException]
An exception occurred while executing 'INSERT INTO s_core_config_values (`element_id`, `shop_id`, `value`) VALUES (
(SELECT id FROM s_core_config_elements WHERE `name` LIKE 'assetTimestamp' LIMIT 1),
) ON DUPLICATE KEY UPDATE s_core_config_values.value = ?;' with params [1, "i:1493713873;", "i:1493713873;"]:
SQLSTATE[HY000]: General error: 1030 Got error -1 from storage engine
[PDOException]
Das sagen die Error-Logs…
[Tue May 02 10:16:43.950461 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: PHP Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[HY000]: General error: 1030 Got error -1 from storage engine' in /var/www/clients/client3/web23/web/engine/Shopware/Components/Session/PdoSessionHandler.php:330, referer: https://www.XXXXXXXXXXXXX.com/sale/
[Tue May 02 10:16:43.950485 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: Stack trace:, referer: https://www.XXXXXXXXXXXXXcom/sale/
[Tue May 02 10:16:43.950488 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: #0 /var/www/clients/client3/web23/web/engine/Shopware/Components/Session/PdoSessionHandler.php(330): PDOStatement->execute(), referer: https://www.XXXXXXXXXXXXX.com/sale/
[Tue May 02 10:16:43.950491 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: #1 [internal function]: Shopware\\Components\\Session\\PdoSessionHandler->write('8cf2a962a2fe94c...', 'Shopware|a:7:{s...'), referer: https://www.XXXXXXXXXXXXX.com/sale/
[Tue May 02 10:16:43.950493 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: #2 [internal function]: session_write_close(), referer: https://www.XXXXXXXXXXXXX.com/sale/
[Tue May 02 10:16:43.950496 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: #3 {main}, referer: https://www.XXXXXXXXXXXXX.com/sale/
[Tue May 02 10:16:43.950498 2017] [fcgid:warn] [pid 19928] [client X.XXX.XXX.XX:33571] mod_fcgid: stderr: thrown in /var/www/clients/client3/web23/web/engine/Shopware/Components/Session/PdoSessionHandler.php on line 330, referer: https://www.XXXXXXXXXXXXX.com/sale/
Wie kann ich den Fehler beheben???
