hoffe auf eure Hilfe. Das Thema gibt es schon öfter, habe auch alles versucht, komme jedoch nicht mehr ins Backend. Fehlermeldung:
Die nachfolgenden Hinweise sollten Dir weiterhelfen.
The provided CSRF-Token is invalid. If you're sure that the request to path "/Onlineshop/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in engine/Shopware/Components/CSRFTokenValidator.php on line 110
Stack trace:
#0 engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#2 engine/Library/Enlight/Controller/Action.php(142): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#3 engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('indexAction')
#4 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch()
#6 vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
Ich habe das Bootstrap-Theme bzw. ein eigenes Theme als Plugin laufen. Shopware ist auf dem neuesten Stand, sprich 5.3.7.
Heute vormittag ging alles noch und ich habe sehr viele Artikel angelegt. Jetzt am abend, obwohl PC nie ausgeschalten kam auf einmal die Fehlermeldung und es wird nur unaufhörlich das „Login wird geladen“ bzw. eben diese Fehlermeldung angezeigt.
Hoffe auf eine Lösung, da sonst die Arbeit von 3 Wochen Artikelanlage, Eigenschaften usw. futsch sind und ich wieder von vorne anfangen muss.
[2018-02-12 20:47:08] core.CRITICAL: SQLSTATE[HY000]: General error: 1015 Can't lock file (errno: 165 - Table is read only) [] {"uid":"a4a6d41"}
[2018-02-12 20:48:28] core.CRITICAL: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. [] {"uid":"efe51b3"}
[2018-02-12 20:48:28] core.ERROR: Shopware\Components\CSRFTokenValidationException: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/CSRFTokenValidator.php:110 Stack trace: #0 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs)) #1 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Action.php(142): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs)) #3 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('indexAction') #4 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch() #6 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/.sites/74/site2991830/web/xxx/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} [] {"uid":"efe51b3"}
[2018-02-12 21:52:28] core.CRITICAL: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. [] {"uid":"4c3fc28"}
[2018-02-12 21:52:28] core.ERROR: Shopware\Components\CSRFTokenValidationException: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/CSRFTokenValidator.php:110 Stack trace: #0 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs)) #1 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Action.php(142): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs)) #3 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('indexAction') #4 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch() #6 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/.sites/74/site2991830/web/xxx/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} [] {"uid":"4c3fc28"}
[2018-02-12 21:57:29] core.CRITICAL: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. [] {"uid":"41c80b0"}
[2018-02-12 21:57:29] core.ERROR: Shopware\Components\CSRFTokenValidationException: The provided CSRF-Token is invalid. If you're sure that the request to path "/xxx/backend/Login?file=app&no-cache=1518464904" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/CSRFTokenValidator.php:110 Stack trace: #0 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs)) #1 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Action.php(142): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs)) #3 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('indexAction') #4 /home/.sites/74/site2991830/web/xxx/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch() #6 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /home/.sites/74/site2991830/web/xxx/vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/.sites/74/site2991830/web/xxx/engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/.sites/74/site2991830/web/xxx/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} [] {"uid":"41c80b0"}
[2018-02-12 22:22:03] core.CRITICAL: SQLSTATE[HY000]: General error: 1015 Can't lock file (errno: 165 - Table is read only) [] {"uid":"8fdf678"}
