Problem beim Laden des Backends
Hallo Leute,
nachdem ich die Shopware Software geupdatet habe, habe ich folgendes Problem beim einloggen in unser Backend:
The provided CSRF-Token is invalid. If you're sure that the request to path "/backend/Login?file=app&no-cache=1498814335" should be valid, the called controller action needs to be whitelisted using the CSRFWhitelistAware interface. in engine/Shopware/Components/CSRFTokenValidator.php on line 110
Stack trace:
#0 [internal function]: Shopware\Components\CSRFTokenValidator->checkBackendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#2 engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#3 engine/Library/Enlight/Controller/Action.php(143): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#4 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#5 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#6 engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#7 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#11 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#12 {main}
Über einen Guide habe ich versucht den Token zu deaktivieren. Leider hat das auch nicht funktioniert.
Die meisten sachen von dieser Seite haben mir leider nicht weiter geholfen.
Hat irgendjemand von euch eine spontane Idee?
Hallo
hast du schon mal den Browser-Cache gelöscht?
Gruß
Mirko
haben es nicht nur mit einem Browser und Endgerät versucht. Aber ja trotzdem wurde regelmäßig der Cache geleert bzw. wurde im Incognito gearbeitet um erst keinen zu bekommen.
Mfg
moin
ich habe auch dieses Problem gehabt. Wenn ich die Kategorien bearbeiten möchte, sehe ich auch folgende Fehlebericht
License check for module “CbaxAdvancedMenuModifiedSw5” has failed. in engine/Shopware/Plugins/Community/Frontend/CbaxAdvancedMenuModifiedSw5/Bootstrap.php on line 323
Stack trace:
#0 engine/Shopware/Plugins/Community/Frontend/CbaxAdvancedMenuModifiedSw5/Bootstrap.php(290): Shopware\_Plugins\_Frontend\_CbaxAdvancedMenuModifiedSw5\_Bootstrap-\>checkLicense(true)
 #1 engine/Shopware/Plugins/Community/Frontend/CbaxAdvancedMenuModifiedSw5/Bootstrap.php(399): Shopware\_Plugins\_Frontend\_CbaxAdvancedMenuModifiedSw5\_Bootstrap-\>checkShopLicense()
 #2 engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Frontend\_CbaxAdvancedMenuModifiedSw5\_Bootstrap-\>loadBackendModuleCategory(Object(Enlight\_Controller\_ActionEventArgs))
 #3 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #4 engine/Library/Enlight/Controller/Action.php(192): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #5 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction')
 #6 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #7 engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\>dispatch()
 #8 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #9 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #11 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #12 shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #13 {main}
bei Dir ist die Lizenz für das Plugin “CbaxAdvancedMenuModifiedSw5” abgelaufen …
VG
leider bringt mich das mit meinem Problem nicht näher an eine Lösung ran.
Mfg
Falls Du gar nicht mehr ins Backend kommst, um dieses Plugin zu deaktivieren, bleibt Dir nichts anderes übrig, als dieses direkt in der Datenbank-Tabelle s_core_plugins zu deaktivieren.
VG
Vielen Dank für die Antwort. Ich habe gerade mal per phpmyadmin in die Datenbank geschaut. Dort ist dieses Plugin nicht mit aufgelistet.
#edit: Ich glaube da gab es eine Verwechslung mit erhan27tr
