Hallo, unser Shop wirft seit geraumer Zeit folgenden Fehler aus, den wir jedoch noch “gefunden” haben weil wir den E-Mail Report aktiviert haben - könnt ihr uns sagen wo der Fehler liegt? [2014-03-27 09:41:34] core.ERROR: exception 'Enlight\_Controller\_Exception' with message 'Permission denied' in /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:249 Stack trace: #0 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(201): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>checkAuth() #1 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onPreDispatchBackend(Object(Enlight\_Controller\_ActionEventArgs)) #2 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #3 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Library/Enlight/Controller/Action.php(138): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #4 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('createLogAction') #5 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #6 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #7 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/customers/webs/rohrstarDE/rohrstar-system/shopware/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main} [] []
Hallo, hast du dazu schon mehr heraus finden können? Wir haben eine ähnliche Fehlermeldung erhalten und wissen nun auch nicht so Recht… Jedoch haben wir auch das Problem, dass Kunden sich nicht mehr registrieren können und einfach auf einer Fehlerseite landen. Wir haben das bislang dadurch behoben, den Cache per FTP zu löschen (vorsichtshalber alle paar Stunden noch von Hand) und den Ordner Chache–> Template neu mit Schreibrechten anlegen. Falls es hier einen Zusammenhang geben könnte … ?
wir bekommen das hier [2014-04-11 00:11:44] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Unauthorized’ in /www/htdocs/w011cb83/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:203 Stack trace: #0 /www/htdocs/w011cb83/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs)) #1 /www/htdocs/w011cb83/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /www/htdocs/w011cb83/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_ActionEventArgs)) #3 /www/htdocs/w011cb83/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘getLastOrdersAc…’) #4 /www/htdocs/w011cb83/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /www/htdocs/w011cb83/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #6 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w011cb83/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} neben sporadischen, vor allem nächtlichen anderen Fehlermeldungen. Frage mich, ob das normal sein soll, nicht so schlimm ist, oder was da klemmt ?
Hallo, bekommt ihr diese Meldungen nur per Mail, oder tauchen die im Shop irgendwo auf? Ähnlich wie das Plugin „debug“ ist die Funktion der e-Mail-Benarichtigung eher dazu gedacht einzelne Fehler im Shop zu debuggen, denn hier werden z.B. auch Warnungen oder reguläre Meldungen die beim Betrieb von Shopware auftreten an Ihre Mailadresse weitergeleitet. Die übermittelte Fehlermeldung kann ein Problem sein, kann aber auch im regulären Betrieb auftreten. Das einfachste wäre hier im Access-Log des Servers nachzusehen welche URL zu dieser Uhrzeit aufgerufen wurde. Wenn über die URL ein reproduzierbarer Fehler entsteht, so kann man dies debuggen, wenn der Fehler allerdings nicht reproduzierbar ist, so kann es sich z.B. um eine Meldung handeln die keine Auswirkungen auf den Shopbetrieb hat und für Kunden nicht sichtbar ist. Generell empfehlen wir diese Funktion nur zu aktivieren, wenn es einen Fehler im Shop gibt den ihr debuggen möchtet. Grüße aus dem Münsterland Patrick Schücker
kommt per Mail Momentan ist der Shop noch im Testbetrieb, ich selbst habe bei Probekäufen noch keine Fehlermeldung gesehen.
Hi, dann kannst du das erst mal wie gesagt einfach ignorieren. Wenn du auf das debugging nicht angewiesen bist, deaktiviere am besten die eMail Benachrichtigung. Gruß Patrick Schücker
ok, man macht sich allerdings schon Gedanken, wenn man morgens 92 Fehlermeldungen im Postfach findet - siehe meinen anderen Post
gerade wieder gut 50 Mails [2014-04-11 19:19:05] core.ERROR: exception ‚Zend_Currency_Exception‘ with message ‚Currency ‚EUR‘ not found‘ in /www/htdocs/w011cb83/engine/Library/Zend/Currency.php:124 Stack trace: #0 /www/htdocs/w011cb83/engine/Shopware/Components/DependencyInjection/Bridge/Currency.php(49): Zend_Currency->__construct(‚EUR‘, Object(Zend_Locale)) #1 /www/htdocs/w011cb83/cache/proxies/Shopware201402131706ProductionProjectContainer.php(131): Shopware\Components\DependencyInjection\Bridge\Currency->factory(Object(Shopware201402131706ProductionProjectContainer), Object(Zend_Locale)) #2 /www/htdocs/w011cb83/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(312): Shopware201402131706ProductionProjectContainer->getCurrencyService() #3 /www/htdocs/w011cb83/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container->get(‚currency‘) #4 /www/htdocs/w011cb83/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container->load(‚currency‘) #5 /www/htdocs/w011cb83/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container->get(‚Currency‘) #6 /www/htdocs/w011cb83/engine/Shopware/Models/Shop/Shop.php(679): Shopware_Bootstrap->getResource(‚Currency‘) #7 /www/htdocs/w011cb83/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(158): Shopware\Models\Shop\Shop->registerResources(Object(Shopware_Proxies_ShopwareBootstrapProxy)) #8 /www/htdocs/w011cb83/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Core_Router_Bootstrap->onRouteStartup(Object(Enlight_Controller_EventArgs)) #9 /www/htdocs/w011cb83/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_EventArgs)) #10 /www/htdocs/w011cb83/engine/Library/Enlight/Controller/Front.php(170): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_EventArgs)) #11 /www/htdocs/w011cb83/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #12 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #14 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #15 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #16 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #18 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #19 /www/htdocs/w011cb83/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #20 {main} bekommen. Ich tue mich schwer mit der Vorstellung, dass das normal sein soll. Natürlich kann ich die Mails abschalten, aber die Fehler bleiben doch … P.S.: Jetzt war der Shop dann auch irgendwie ganz weg vom Fenster - ich mußte SÄMTLICHE Caches leeren, bevor etwas ging. Regelmäßig verstellt der Shop dabei auch die Zugriffsrechte des log-Ordners, so dass ich diese manuell per FTP wieder auf Schreibrechte setzen muß. Any ideas ?
Guten Morgen, gab es seit dem leeren des Caches weitere Fehler? In Shopware gibt es keine Funktion, die Rechte ändert. Du solltest wegen dem LOG Ordner vielleicht einmal mit deinem Hoster Rücksprache halten. Gruß Patrick Schücker
wir sind wegen entsprechender Empfehlungen bei all-inkl. Wir haben regelmäßig nach Entleeren des Caches - was beim Neuaufsetzen eines Shops wegen neuer Kategorien und Seiten ja noch häufig notwendig ist - beim Neuladen im Browser Fehlermeldungen wegen falscher Zugriffsrechte von /logs. Manchmal sind die dann wirklich falsch/geändert, manchmal aber auch nicht. Wir setzen dann per FTP die Rechte hin und her und dann geht es auch im Browser wieder. Da ich die Versendung der Fehlermeldungen jetzt nach Ihrem Rat ja ausgeschaltet habe, weiß ich nicht, ob sich nun was geändert hat. Bisher hagelte es Fehlermeldungen vor allem immer nachts - Shop läuft jetzt testweise aber praktisch ohne jeglichen Nutzerverkehr.
das erscheint als Fehlermeldung im Browser praktisch nach jedem Cache leeren und geht erst weg über FTP Rechte setzen Fatal error: Uncaught exception ‘RuntimeException’ with message 'Unable to write in the logs directory (/www/htdocs/w011cb83/logs) ’ in /www/htdocs/w011cb83/engine/Shopware/Kernel.php:428 Stack trace: #0 /www/htdocs/w011cb83/engine/Shopware/Kernel.php(314): Shopware\Kernel->buildContainer() #1 /www/htdocs/w011cb83/engine/Shopware/Kernel.php(235): Shopware\Kernel->initializeContainer() #2 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(250): Shopware\Kernel->boot() #3 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #4 /www/htdocs/w011cb83/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #5 /www/htdocs/w011cb83/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\ in /www/htdocs/w011cb83/engine/Shopware/Kernel.php on line 428
Hallo, das Problem ist bekannt bei Nutzern von Allinkl. Hier findest du eine Anleitung zur Behebung des “Log”-Ordner-Problemes: post84316.html#p84316 Viele Grüße Moritz Naczenski
Hallo wenn ich unter Performance alles auswähle und den Cache leere, dann bekomme ich folgende Fehlermeldung: [2014-04-22 14:33:56] core.ERROR: exception 'RuntimeException' with message 'SplFileInfo::getSize(): stat failed for /var/www/KD01/htdocs/dildo-discount.com/cache/templates/backend\_de\_DE\_46b91/5d/c9' in /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/CacheManager.php:350 Stack trace: #0 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/CacheManager.php(350): SplFileInfo-\>getSize() #1 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/CacheManager.php(256): Shopware\Components\CacheManager-\>getDirectoryInfo('/var/www/KD01/h...') #2 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Controllers/Backend/Cache.php(65): Shopware\Components\CacheManager-\>getTemplateCacheInfo() #3 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Cache-\>getInfoAction() #4 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getInfoAction') #5 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #6 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #7 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/www/KD01/htdocs/dildo-discount.com/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main} [] [] Woran kann es liegen? LG Mirko
Hallo Ich habe mal in den System-Informationen gestöbert und folgendes gefunden. Kann es denn damit auch zusammen hängen? Siehe Screenshot: Bepado Plugin habe ich gelöscht. Aber trotzdem wird es angezeigt. Paypal Plugin habe ich neuinstalliert aber immer noch das gleiche wie im Screenshot LG Mirko Lange
Hallo Mirko, das das Plugin rot markiert wird ist normal. Kannst es hier im Wiki auch nachlesen. Dadurch sollte die Mail nicht ausgelöst werden. Nutzt du den HTTP Cache? Falls ja, deaktiviere diese, lösche den Cache und aktiviere den Cache danach wieder. Gruß Patrick
Push: Hab leider auch das Problem mit den Emails und den Fehlermeldungen. Im Fronten nichts gefunden jedoch mach ich mir schon Gedanken. Gibt es da keine Lösung die für alle gleich ist? Ich hab einen eignen root Server… na was soll ich da jetzt machen? Wurde das Problem noch nicht behoben oder hart sonst niemand das Problem. Hab Shopware 4.2.3 Bitte rollt das Thema noch einmal auf, ich glaube nicht das es für alle klar ist. Wie auch für mich nicht.
Hab das Problem leider auch, sehe keinen Ansatz. [2014-07-11 16:28:10] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Action “Frontend_Detail_resourceAction” not found failure’ in /home/httpd/midistore/engine/Library/Enlight/Controller/Action.php:389
Auch ich habe eine Menge Fehlermeldungen im Log Ordner. Datei: core_production-2014-08-08.log Inhalt: [2014-08-08 02:56:43] core.ERROR: exception 'Enlight\_Controller\_Exception' with message 'Unauthorized' in /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:203 Stack trace: #0 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onPreDispatchBackend(Object(Enlight\_Controller\_ActionEventArgs)) #1 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #2 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Library/Enlight/Controller/Action.php(138): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #3 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getVisitorsActi...') #4 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #6 /var/www/vhosts/topSecret/update/4-2/topSecret/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /var/www/vhosts/topSecret/update/4-2/topSecret/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /var/www/vhosts/topSecret/update/4-2/topSecret/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/vhosts/topSecret/update/4-2/topSecret/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} [] {"uid":"0c2bb7a"} ... Davon habe ich ca. 15 Stück im Ordner mit jeweils über 1.000 Zeilen. Der Shop läuft zwar, aber die Fehlermeldungen möchte ich dennoch ungerne sehen, vorallem weil die den Log voll müllen. Da muss es doch eine Lösung für geben?
Hallo, wir haben diese Fehlermeldung auch: >> exception ‚Enlight_Controller_Exception‘ with message ‚Unauthorized‘ Im Übrigen tritt diese immer auf, wenn man im Backend ohne grund „rausgeschmissen“ wurde und wieder beim Login-Bildschirm landet… Das ist sehr frustrierend - besonders dann, wenn man vorher lange Produktbeschreibungen geschrieben hat und dann alles weg ist… Gruss
Hallo, gibt es hierzu schon neuere Erkenntnisse ? Verwenden 4.2.3 und ständig die mails: [2015-04-14 06:19:59] core.ERROR: exception ‚Enlight_Controller_Exception‘ with message ‚Permission denied‘ in /var/www/vhosts/domain-XXXXXX/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:249 Stack trace: #0 /var/www/vhosts/domain-XXXXXX/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(201): Shopware_Plugins_Backend_Auth_Bootstrap->checkAuth() #1 /var/www/vhosts/domain-XXXXXX/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs)) #2 /var/www/vhosts/domain-XXXXXX/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs)) #3 /var/www/vhosts/domain-XXXXXX/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #4 /var/www/vhosts/domain-XXXXXX/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‚createLogAction‘) #5 /var/www/vhosts/domain-XXXXXX/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #6 /var/www/vhosts/domain-XXXXXX/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #7 /var/www/vhosts/domain-XXXXXX/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /var/www/vhosts/domain-XXXXXX/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /var/www/vhosts/domain-XXXXXX/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/vhosts/domain-XXXXXX/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/www/vhosts/domain-XXXXXX/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main} Bitte um Info wenn jemand helfen kann. Danke Alois
