Please assist in resolving the issue below. I also contacted my hosting service provider but could not find anything wrong in the server PHP error log.Please assist in resolving the issue below. I also contacted my hosting service provider but could not find anything wrong in the server PHP error log.
!(file:///C:\Users\REDAPP~1\AppData\Local\Temp\msohtmlclip1\01\clip_image001.png)
Hello @Kwazi083_,
unfortunately your attached image is not loading properly.
Can you try to describe what’s happening once you open the checkout page?
Kind regards,
Patrick
Hi [@Patrick Stahl](http://forum.shopware.com/profile/1869/Patrick Stahl “Patrick Stahl”),
Please find the screenshot for my error message.
Regards,
Kwazi
Hey @Kwazi083_,
this seems to be an actual PHP server error then.
You should find more detailed information about that issue in your server logs, your hoster might help you with that task.
Also you could try to enable the debug configuration of Shopware, as this might also print the actual core error message.
Regards,
Patrick
