Cart Loading problem
Hai to all, In Shopware,when I add to cart a product,The product not to add in cart,It’s only loading. When I check this in chrome at [color=red]Console[/color],It shows following Error Failed to load resource: the server responded with a status of 503 (Service Unavailable) Please help in this above problem Thankyou…
Hello, please have a look at the shopware lofiles (/var/log/ in the shopware directory). There should be an entry with an error message. Moritz
Hai Moritz., Thank you for your timely response. I have checked logs folder in /www/htdocs/logs There is no log files in the folder. For eg., http://www.xclusive-snakes.de/neu-im-sh … ebald?c=42 Please check the error in the above Link. Just Click the „In den Warenkorb“ button.You can see the error Thanks in advance
Hai., You can see the following Error in chrome at „console“ [color=red]http://www.xclusive-snakes.de/checkout/ajaxCart?callback=jQuery21102658743893261999_1452000752330&_=1452000752333Failed to load resource: the server responded with a status of 503 (Service Unavailable)[/color] [color=red]http://www.xclusive-snakes.de/checkout/ajaxAddArticleCart?callback=jQuery21102658743893261999_1452000752330&sActionIdentifier=&sAddAccessories=&sAdd=1515_m-Ivory_01&sQuantity=1&isXHR=1&_=1452000752334Failed to load resource: the server responded with a status of 503 (Service Unavailable)[/color]
Hello, there should still be an error in the shopware error log. But you can try to deactivate your plugins step by step, perhaps the error is caused by a plugin. Moritz
I’ve got the same problem. I don’t get any errors in the logfile. The console shows
GET https://xxx/dev/checkout/ajaxAddArticleCart?callback=jQuery211…81049764156_1457954844070&sAdd=KR10007&sQuantity=1&isXHR=1&_=1457954844072 503 (Service Unavailable)
But after that:
XHR finished loading: GET “https://xxx/dev/checkout/ajaxAddArticleCart?callback=jQuery211…81049764156_1457954844070&sAdd=KR10007&sQuantity=1&isXHR=1&_=1457954844072”.
When I click the link I get a result back.
In Firefox-Console the answer is:
jQuery21105231256060663151_1457955995905("Ein Fehler ist aufgetreten.\n\n\tBitte versuchen Sie es sp\u00e4ter nochmal.\n");
I deactivated the last plugin I installed - It worked last week with the Plugin, but anyway… - but no change.
Any further ideas? Why did you  remove the Developer Toolbar Plugin from the store?
Regards,
Cat.
Ok, I installed the debug-Plugin and found out, that there is a comma where it should not be in „Erweiterte SQL Abfage“ in „Versandkosten-Modul“ in the Shop Settings.
Now everything is working!
regards,
Cat.
