Resource license not found failure
httpdocs/engine/Shopware/Components/DependencyInjection/Container.php on line 192
503 Service Unavailable
Bekomme ich nach dem klicken auf neuinstallation vom Lizenz-Manager. Was kann ich hier jetzt machen??
Hast Du es gelöst?
Ich habe bei einem Shop genau das selbe Problem, allerdings beim Update des License Managers auf 1.2.0
Bitte um Hilfe!
Oops! An error has occurred!
The following notes should help you.
Resource “license” not found failure in Shopware/Components/DependencyInjection/Container.php on line 192
Stack trace:
 #0 Enlight/Plugin/Bootstrap.php(116): Shopware\Components\DependencyInjection\Container-\>get('license') #1 Shopware/Plugins/Community/Backend/SwagDigitalPublishing/Bootstrap.php(373): Enlight\_Plugin\_Bootstrap-\>get() #2 Shopware/Plugins/Community/Backend/SwagDigitalPublishing/Bootstrap.php(312): Shopware\_Plugins\_Backend\_SwagDigitalPublishing\_Bootstrap-\>checkLicenseCore() #3 Shopware/Plugins/Community/Backend/SwagDigitalPublishing/Bootstrap.php(148): Shopware\_Plugins\_Backend\_SwagDigitalPublishing\_Bootstrap-\>checkLicense() #4 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_SwagDigitalPublishing\_Bootstrap-\>registerSubscriber(Object(Enlight\_Controller\_ActionEventArgs)) #5 Enlight/Event/EventManager.php(213): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #6 Enlight/Controller/Action.php(137): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #7 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction') #8 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #9 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch() #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #14 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main}
Lösung bei mir:
Digital Publishing aus dem Plugins Ordner schieben, dann geht das Backend wieder.
Lizenmanager war nach dem Update inaktiv (nicht zm ersten mal bei einem Plugin-Update), also aktivieren
Digital Publishing Ordner wieder zurück schieben und die verknüpften Einkaufswelten löschen und neu anlegen, weil irgendeine Zuordnung verloren geht.
Blöd!
Ganz so einfach war es dann auch nicht, aber Danke für den Schubser in die richtige Richtung.
SwagFuzzy musste auch noch rausgenommen werden, das das Backend wieder funktioniert hat.
Shopware version 5.1.3
Datum 2017-10-06
Falls das Problem noch besteht bzw. für andere die genau auf dieses Problem stossen. Die Lösung ist ganz ein einfach.
  1. Nach dem Plugin in der Datenbank suchen.
SELECT * FROM s_core_plugins WHERE label=’’;
  1. Den Eintrag ‚active‘ von den betroffenen Modul auf 0 setzen.
    UPDATE s_core_plugins SET active=0;
