Moin, wir haben auf unserem Dev System festgestellt, dass wenn PHP Sessions mit igbinary[1] erstellt wurden, der Shop an sich funktioniert. Sobald man dann aber zur Kasse/Checkout geht die Session gelöscht wird. Andere Systeme funktionieren damit ohne Probleme. Die Konfiguration, stand auf: session.serialize\_handler=igbinary PHP Standard ist: session.serialize\_handler=serialize es erscheint die Fehlermeldung: exception 'Zend\_Session\_Exception' with message 'Zend\_Session::start() - /var/customers/webs/buongusto/shopware/engine/Library/Zend/Session.php(Line:484): Error #2 session\_start(): Failed to decode session object. Session has been destroyed' in /var/customers/webs/buongusto/shopware/engine/Library/Zend/Session.php:504 Stack trace: #0 /var/customers/webs/buongusto/shopware/engine/Shopware/Bootstrap.php(205): Zend\_Session::start(Array) #1 [internal function]: Shopware\_Bootstrap-\>initSession() #2 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Bootstrap.php(304): call\_user\_func(Array) #3 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Bootstrap.php(258): Enlight\_Bootstrap-\>loadResource('Session') #4 /var/customers/webs/buongusto/shopware/engine/Shopware/Application.php(172): Enlight\_Bootstrap-\>getResource('Session') #5 /var/customers/webs/buongusto/shopware/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(304): Shopware-\>Session() #6 /var/customers/webs/buongusto/shopware/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(196): Shopware\_Plugins\_Core\_Router\_Bootstrap-\>upgradeShop(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #7 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Core\_Router\_Bootstrap-\>onRouteShutdown(Object(Enlight\_Controller\_EventArgs)) #8 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Event/EventManager.php(156): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_EventArgs)) #9 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Controller/Front.php(176): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_EventArgs)) #10 /var/customers/webs/buongusto/shopware/engine/Shopware/Bootstrap.php(79): Enlight\_Controller\_Front-\>dispatch() #11 /var/customers/webs/buongusto/shopware/engine/Library/Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #12 /var/customers/webs/buongusto/shopware/shopware.php(74): Enlight\_Application-\>run() #13 {main} Meine Ansicht ist es kein richtiger Bug. Nur für andere als Hinweis hier, falls der Fehler auftreten sollte ^^ [1] http://pecl.php.net/package/igbinary
