Hallo, unser Shopware Shop funktioniert und Bestellungen sind auch ausführbar. Allerding bekomme ich über den Tag verteilt immer die gleichen 2 Fehlermeldungen: Bisher kann ich mir aber die Ursache nicht erklären. Fehler 1: exception 'Zend\_Session\_Exception' with message 'The session has already been started. The session id must be set first.' in /www/htdocs/w0125fd2/shopware/engine/Library/Zend/Session.php:709 Stack trace: #0 /www/htdocs/w0125fd2/shopware/engine/Library/Zend/Session.php(421): Zend\_Session::setId('da602f0b162fccb...') #1 /www/htdocs/w0125fd2/shopware/engine/Library/Zend/Session/Namespace.php(143): Zend\_Session::start(true) #2 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/DependencyInjection/Bridge/Session.php(81): Zend\_Session\_Namespace-\>\_\_construct('Shopware') #3 /www/htdocs/w0125fd2/shopware/cache/proxies/Shopware201409241139ProductionProjectContainer.php(275): Shopware\Components\DependencyInjection\Bridge\Session-\>factory(Object(Shopware201409241139ProductionProjectContainer)) #4 /www/htdocs/w0125fd2/shopware/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(312): Shopware201409241139ProductionProjectContainer-\>getSessionService() #5 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('session') #6 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('session') #7 /www/htdocs/w0125fd2/shopware/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Session') #8 /www/htdocs/w0125fd2/shopware/engine/Shopware/Application.php(196): Shopware\_Bootstrap-\>getResource('Session') #9 /www/htdocs/w0125fd2/shopware/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(342): Shopware-\>Session() #10 /www/htdocs/w0125fd2/shopware/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(230): Shopware\_Plugins\_Core\_Router\_Bootstrap-\>upgradeShop(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #11 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Core\_Router\_Bootstrap-\>onRouteShutdown(Object(Enlight\_Controller\_EventArgs)) #12 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_EventArgs)) #13 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Controller/Front.php(190): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_EventArgs)) #14 /www/htdocs/w0125fd2/shopware/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #15 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #16 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #17 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #18 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #19 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #20 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #21 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #22 /www/htdocs/w0125fd2/shopware/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #23 {main} Channel: core request: { „uri“: „/“, „method“: „GET“, „query“: , „post“: } session: No session data available shopId: 1 shopName: Deutsch Zweiter Fehler: exception 'Enlight\_Exception' with message 'Could not construct form class' in /www/htdocs/w0125fd2/shopware/engine/Shopware/Controllers/Frontend/Forms.php:80 Stack trace: #0 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Frontend\_Forms-\>indexAction() #1 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('indexAction') #2 /www/htdocs/w0125fd2/shopware/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #3 /www/htdocs/w0125fd2/shopware/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #4 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #5 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #6 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #7 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #8 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w0125fd2/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w0125fd2/shopware/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 /www/htdocs/w0125fd2/shopware/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main} Channel: core request: { „uri“: „/support/index/sfid/16/sinquiry/detail/sordernumber/2.000.9458“, „method“: „GET“, „query“: { „controller“: „support“, „action“: „index“, „sfid“: „16“, „sinquiry“: „detail“, „sordernumber“: „2.000.9458“ }, „post“: } session: { „sessionId“: „f567bea471b84fa192b1f3c5ec83efe06d5a4089“, „Bot“: true, „sOutputNet“: true } Über Hinweise und Lösungen würde ich mich sehr freuen.
Aus den Accesslogs kann ich entnehmen, dass zum Zeitpunkt des Fehlers der Baiduspider auf die Seite zugreift. „Ziele“ sind überwiegend PDFs, Css Dateien und /
