One-Klick-Installer bricht ab in Step 1/2
Servus aus München in die Runde,
Environment:
Synology NAS, MariaDB 10, php 5.6, Apache 2.2.
Hätte gern php7 und Apache 2.4, aber das war nicht ans Laufen zu bringen. Es kostet einige graue Haare bis man überhaupt mal vorwärts kommt. Alle Verzeichnisrechte zu 777, Nicht localhost verwenden, sondern IP, Port 3307 und nicht 3306, http-User der NAS ein Systemuser braucht Schreibrechte, root-user auf externen Zugriff stellen. Plug-and-Pray…
Nun komme ich aber nicht mehr so recht weiter … Ideen Eurerseits wären exterminatorisch.
Liebe Grüße
Peter
Fehler:
Error
**Received an error message.
URL: importDatabase?offset=1700&totalCount=2297
Message: Internal Server Error
Please try to fix this error and restart the update.**
Response
Slim Application Error
Type: RuntimeException
Message: Identifier DB not initialized yet
File: /volume1/web/shopware/recovery/install/src/ContainerProvider.php
Line: 162
Trace
#0 /volume1/web/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#1 /volume1/web/shopware/recovery/install/src/app.php(540): Pimple\Container->offsetGet(‚db‘)#2 [internal function]: {closure}()#3 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#4 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#5 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#6 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#7 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#8 /volume1/web/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#9 /volume1/web/shopware/recovery/install/index.php(75): Slim\Slim->run()
#10 {main}
Edit:
Die Datenbanken wurde aber angelegt. Den Installer nochmal gestartet und er lief durch.
Im Backend nach Sprachenauswahl:
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‘INSERT INTO s_core_config_values (element_id, shop_id, value) VALUES ( (SELECT id FROM s_core_config_elements WHERE name LIKE ‘trackingUniqueId’ LIMIT 1), 1, ? )’ with params [“s:32:“5uzvOhhTqxqozBigq7NNNdfQLizuv9lr”;”]: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘966-1’ for key ‘element_id_shop_id’ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(996): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‘INSERT INTO s_c…’, Array) #1 engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(103): Doctrine\DBAL\Connection->executeUpdate(‘INSERT INTO s_c…’, Array) #2 engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(62): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator->storeUniqueIdInDb(‘5uzvOhhTqxqozBi…’) #3 engine/Shopware/Bundle/PluginInstallerBundle/StoreClient.php(293): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator->getUniqueId() #4 engine/Shopware/Controllers/Backend/FirstRunWizardPluginManager.php(236): Shopware\Bundle\PluginInstallerBundle\StoreClient->doTrackEvent(‘First Run Wizar…’) #5 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_FirstRunWizardPluginManager->getAvailableLocalizationsAction() #6 engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch(‘getAvailableLoc…’) #7 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #8 engine/Shopware/Kernel.php(189): Enlight_Controller_Front->dispatch() #9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main}
OK
Erspare Dir den Krampf und sorge erstmal für: http://community.shopware.com/Systemanforderungen_detail_1840.html
Die Systemanforderungen sind gegeben. Nun gehts beim Speichern der Shop-Grundeinstellungen plötzlich zurück zum Schritt der Datenbankeingabe.
Jugend forscht :slight_smile:
Mittlerweile läufts. Danke an meinen Hoster / Provider.
