Fehler beim Setup
ich melde mich mit einem neun Fehler. Dieser tritt während der Installation via. des Setups auf.
Habe mehrere neue Datenbanken getestet!
Danke im vorraus.
Error
Received an error message.
URL: importDatabase?offset=1100&totalCount=2406
Message: Internal Server Error
Response
Slim Application Error
Type: RuntimeException
Message: Identifier DB not initialized yet
File: /var/www/html/fashionpassion/recovery/install/src/ContainerProvider.php
Line: 155
Trace
#0 /var/www/html/fashionpassion/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#1 /var/www/html/fashionpassion/recovery/install/src/app.php(539): Pimple\Container->offsetGet(‘db’)
#2 [internal function]: {closure}()
#3 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#4 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#5 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#6 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#7 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#8 /var/www/html/fashionpassion/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#9 /var/www/html/fashionpassion/recovery/install/index.php(75): Slim\Slim->run()
#10 {main}
Error
Response
Line: 155
Trace
#10 {main}
Ich nehme mal an Shopware 5.6.2 ?
Stimmen die Servervorraussetzungen. insb. die Minimum Version der Datenbank ?
vielleicht hilft auch die Forensuche: https://forum.shopware.com/discussion/48463/installationsfehler-identifier-db-not-initialized-yet
max_execution_time, memory limit …etc
habe ich alles eben geupdatet.
LG
Bump.
Hat sonst noch wer eine Lösung?
Possible solution: https://stackoverflow.com/questions/45637033/shopware-installation-error-identifier-db-not-initialized-yet
I don’t understand why shopware doesn’t solve this… (sorry for english)
