Hello,
i tried to export articles, but give the failur message below. It gives the message on all categories. Does someone know how to solve this? I downloaded the version 5.3.7 recently.
Thank you very much for your help!
An error occured
Oops! An error has occurred!
The following notes should help you.
You have requested a non-existent service „swag_import_export.logger“. in vendor/symfony/dependency-injection/Container.php on line 288
Stack trace:
#0 engine/Shopware/Components/DependencyInjection/Container.php(217): Symfony\Component\DependencyInjection\Container-\>get('swag\_import\_exp...', 1) #1 engine/Shopware/Components/DependencyInjection/Container.php(146): Shopware\Components\DependencyInjection\Container-\>doLoad('swag\_import\_exp...', 1) #2 engine/Shopware/Plugins/Community/Backend/SwagImportExport/Controllers/Backend/SwagImportExport.php(1406): Shopware\Components\DependencyInjection\Container-\>get('swag\_import\_exp...') #3 engine/Shopware/Plugins/Community/Backend/SwagImportExport/Controllers/Backend/SwagImportExport.php(487): Shopware\_Controllers\_Backend\_SwagImportExport-\>getLogger() #4 engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_SwagImportExport-\>prepareExportAction() #5 engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight\_Controller\_Action-\>dispatch('prepareExportAc...') #6 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #7 engine/Shopware/Kernel.php(191): Enlight\_Controller\_Front-\>dispatch() #8 vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #9 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #11 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #12 shopware.php(118): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main}
