Hallo an alle,
nachdem ich heute Nacht die neue Update von SW Installiert habe, habe ich keine zugriff mehr auf meine Bestellungen…
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Undefined method 'getBackendOrdersQuery'. The method name must start with either findBy or findOneBy! in vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php on line 226 Stack trace: #0 engine/Shopware/Plugins/Community/Backend/FriedmOrderlistInvoiceNr/Bootstrap.php(323): Doctrine\ORM\EntityRepository->__call('getBackendOrder...', Array) #1 engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_FriedmOrderlistInvoiceNr_Bootstrap->onHookOrderGetListReplace(Object(Enlight_Hook_HookArgs)) #2 engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Hook_HookArgs)) #3 engine/Library/Enlight/Hook/HookManager.php(182): Enlight_Event_EventManager->notify('Shopware_Contro...', Object(Enlight_Hook_HookArgs)) #4 var/cache/production_201801171346/proxies/ShopwareControllersBackendOrderProxy.php(60): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersBackendOrderProxy), 'getList', Array) #5 engine/Shopware/Controllers/Backend/Order.php(286): Shopware_Proxies_ShopwareControllersBackendOrderProxy->getList(Array, Array, '0', '20') #6 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Order->getListAction() #7 engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('getListAction') #8 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #9 engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch() #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object
R4M
February 12, 2018, 7:01am
2
Eventuell hilft ein Blick in die Logdateien:
Fehlermeldungen in Shopware
NurIch
February 12, 2018, 7:55am
3
von welcher Version auf welche Version wäre nicht schlecht als Info
und dieses Plugin abschalten:
das scheint probleme zu machen
Hallo und Vielen Dank für eure Hilfe!
Also ich wollte eine Plugin Installieren um zu sehen ob es dadran liegt… als ich bei Plugin Manager geklickt habe, habe ich oben rechts folgende meldung bekommen.
Error
Class 'Shopware_Plugins_Frontend_kdzFooterKachelEmotions_Bootstrap' not found
File:/ var/ www/ vhosts/ ideal-deals.de/ httpdocs/ engine/ Shopware/ Components/ Plugin/ Namespace.php
und meine Installierte Plugins werden nicht angezeigt… Aaaber wenn ich auf Sicherheitsmodus klicke, dann habe ich wieder zugriff auf meine Bestellungen.
Soo ich habe das betrofene Plugin gefunde und Gelöscht! Jetzt habe ich wieder zugriff auf meine Bestellungen, aber die Fehler meldung kommt immer noch wenn ich auf PLugin Manager gehe…
kennt das Problem niemand?
@simkli schrieb:
Hallo @ilias-shop
Fehlerausgabe aktivieren (siehe hier Punkt 3: https://forum.shopware.com/discussion/comment/106945#Comment_106945 )
Ajax-Fehlermeldung finden (siehe hier: https://forum.shopware.com/discussion/comment/106944/#Comment_106944 )
Die genaue Fehlermeldung hier posten, dann kann man dir weiterhelfen
leider weiss ich nicht genau wo ich diese sachen finden kann?
z.B wo finde ich den config.php ?
und immer wenn ich mich bei mein Backend anmelde bekomme ich per Email fogede fehlermeldeung.
CRITICAL
Message:
Unauthorized
Time:
2018-02-26T22:45:22.831293+0100
Channel:
core
request:
"uri": "/backend/widgets/getLastOrders?_dc=1519681525095&page=1&start=0&limit=25",
"method": "GET",
"query": {
"_dc": "1519681525095",
"page": "1",
"start": "0",
"limit": "25",
"module": "backend",
"controller": "widgets",
"action": "getLastOrders"
"post": []
shop:
No shop data available
session:
No session data available
CRITICAL
Message:
Unauthorized
Time:
2018-02-26T22:45:22.835191+0100
Channel:
core
request:
"method": "GET",
"query": {
"page": "1",
"start": "0",
"limit": "25",
"post": []
shop:
session:
ERROR
Message:
exception 'Enlight_Controller_Exception' with message 'Unauthorized' in /var/www/vhosts/ideal-deals.de/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:208
Stack trace:
#0 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#1 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(218): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#3 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch('getLastOrdersAc...')
#4 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch()
#6 /var/www/vhosts/ideal-deals.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /var/www/vhosts/ideal-deals.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(251): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/vhosts/ideal-deals.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/vhosts/ideal-deals.de/httpdocs/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
Time:
2018-02-26T22:45:22.835781+0100
Channel:
core
request:
"method": "GET",
"query": {
"page": "1",
"start": "0",
"limit": "25",
"post": []
shop:
session:
also ich habe keine zugriff auf meine Plugins mehr und wenn ich immer auf Install klicke bekomme ich diese Fehlermeldung
kennt das jemand?
Mfg. Ilias C.
kennt das wirklich niemand?
Nö das solltest du reparieren lassen wenn du selber in der Datenbank nicht so fit bist.
