Der Migrationsassistent Version 0.40.0 importiert nur 1 Produkt
Systemfehler aufgetreten: 539
Ein Schreibfehler ist aufgetreten: 1
Log:
[error] SWAG_MIGRATION__WRITE_EXCEPTION_OCCURRED
A write exception has occurred
"entity": "media_folder",
"dataId": "f94bfbe372f84bcfa41cb049cdff297d",
"error": {
"code": "76454e69-502c-46c5-9643-f447d837c4d5",
"status": "400",
"detail": "Dieser Wert sollte gr\u00f6\u00dfer oder gleich 1 sein.",
"template": "This value should be {{ limit }} or more.",
"meta": {
"parameters": {
"{{ value }}": "0",
"{{ limit }}": "1"
"source": {
"pointer": "\/4\/configuration\/mediaThumbnailSizes\/3\/mediaThumbnailSize\/height"
[error] SWAG_MIGRATION_RUN_EXCEPTION
An exception occurred
Entity: product, sourceId: f7c8b5b295b246db8c1075ae53564c35
An exception occurred while executing 'INSERT INTO `media` (`id`, `media_folder_id`, `created_at`) VALUES (?, ?, ?)' with params ["\xd0\xa2\x6f\x12\xd7\x4b\x4a\x74\x9e\xbc\x38\x3f\xbb\x0a\xc9\x49", "\xcb\x23\x6c\x55\x3e\x3d\x47\x23\x88\x73\x68\xcb\xbb\x90\x81\xd7", "2019-12-20 22:33:29.675"]:SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (`d02f29aa`.`media`, CONSTRAINT `fk.media.media_folder_id` FOREIGN KEY (`media_folder_id`) REFERENCES `media_folder` (`id`) ON DELETE SET NULL)
