- Shopware PE 4.3.6 - PHP 5.6.13
Fatal error: Uncaught exception 'InvalidArgumentException' with message 'The directory "/var/www/vhosts/.../httpdocs/cache/doctrine/proxies/201504021339" is not writable.' in /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php:302 Stack trace: #0 /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php(78): Shopware\Components\Model\Configuration-\>setProxyDir('/var/www/vhosts...') #1 /var/www/vhosts/.../httpdocs/cache/proxies/Shopware201504021339ProductionProjectContainer.php(229): Shopware\Components\Model\Configuration-\>\_\_construct(Array, Object(Zend\_Cache\_Core), Object(Enlight\_Hook\_HookManager)) #2 /var/www/vhosts/.../httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(326): Shopware201504021339ProductionProjectContainer-\>getModelconfigService() #3 /var/www/vhosts/.../httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\Depen in /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php on line 302 503 Service Unavailablecache = Rechte 0777 doctrine = Rechte 0777 proxies = Rechte 0777 201504021339 = Rechte 0755 Warum wird dieser belanglose Ordner 201504021339 nicht mit 0777 angelegt? Nein, stattdessen weiße Seite mit 503
Und nein, ich kann den Shop NICHT neu aufsetzen.
Hat keiner ähnliche Probleme?
[quote=“R4M”]- Shopware PE 4.3.6 - PHP 5.6.13 Fatal error: Uncaught exception 'InvalidArgumentException' with message 'The directory "/var/www/vhosts/.../httpdocs/cache/doctrine/proxies/201504021339" is not writable.' in /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php:302 Stack trace: #0 /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php(78): Shopware\Components\Model\Configuration-\>setProxyDir('/var/www/vhosts...') #1 /var/www/vhosts/.../httpdocs/cache/proxies/Shopware201504021339ProductionProjectContainer.php(229): Shopware\Components\Model\Configuration-\>\_\_construct(Array, Object(Zend\_Cache\_Core), Object(Enlight\_Hook\_HookManager)) #2 /var/www/vhosts/.../httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(326): Shopware201504021339ProductionProjectContainer-\>getModelconfigService() #3 /var/www/vhosts/.../httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\Depen in /var/www/vhosts/.../httpdocs/engine/Shopware/Components/Model/Configuration.php on line 302 503 Service Unavailable cache = Rechte 0777 doctrine = Rechte 0777 proxies = Rechte 0777 201504021339 = Rechte 0755 Warum wird dieser belanglose Ordner 201504021339 nicht mit 0777 angelegt? Nein, stattdessen weiße Seite mit 503
Und nein, ich kann den Shop NICHT neu aufsetzen.[/quote] Hallo, wie sind denn die Rechte bei deinem Hoster gesetzt? Nicht bei jedem Hoster hat jede Datei automatisch die Möglichkeit, neue Ordner/Dateien zu erstellen, das muss man oft auch selbst beim Hostingpaket festlegen. Da kann die Shopsoftware selbst nichts dafür. Beste Grüße Sebastian
Jetzt verstehe ich die Frage nicht genau. Server ist ein Root-Server - also wir haben die Macht
Die Cach-Ordner sind alles auf 777 gesetzt. Aber der Ordner unter „proxies“ macht immer wieder Probleme. Im Moment weiß ich nicht gar nicht wie ich das Problem lösen sollte.
