ich versuche von Shopware 6 das Development-Template zu installieren.
Hierbei bricht die Installation bei Step 34 mit der folgenden Ausgabe ab:
(34/46) Starting
PROJECT_ROOT=/some/folder/development ENV_FILE=/some/folder/development/.env npm run --prefix vendor/shopware/platform/src/Administration/Resources/app/administration/ build
> administration@1.0.0 build /some/folder/development/vendor/shopware/platform/src/Administration/Resources/app/administration
> mode=production webpack
# Compiling with Webpack configuration
# Production mode is activated 🚀
# Plugin "Storefront": Injected successfully
Calling reporter service for single check.
Aborted
npm ERR! code ELIFECYCLE
npm ERR! errno 134
npm ERR! administration@1.0.0 build: `mode=production webpack`
npm ERR! Exit status 134
npm ERR!
npm ERR! Failed at the administration@1.0.0 build script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/user/.npm/_logs/2022-01-18T11_02_45_423Z-debug.log
Im Logfile steht:
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli ‚/usr/bin/node‘,
1 verbose cli ‚/usr/bin/npm‘,
1 verbose cli ‚run‘,
1 verbose cli ‚–prefix‘,
1 verbose cli ‚vendor/shopware/platform/src/Administration/Resources/app/administration/‘,
1 verbose cli ‚build‘
1 verbose cli ]
2 info using npm@6.14.15
3 info using node@v12.22.7
4 verbose run-script [ ‚prebuild‘, ‚build‘, ‚postbuild‘ ]
5 info lifecycle administration@1.0.0~prebuild: administration@1.0.0
6 info lifecycle administration@1.0.0~build: administration@1.0.0
7 verbose lifecycle administration@1.0.0~build: unsafe-perm in lifecycle true
8 verbose lifecycle administration@1.0.0~build: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/some/folder/development/vendor/shopware/platform/src/Administration/Resources/app/administration/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
9 verbose lifecycle administration@1.0.0~build: CWD: /some/folder/development/vendor/shopware/platform/src/Administration/Resources/app/administration
10 silly lifecycle administration@1.0.0~build: Args: [ ‚-c‘, ‚mode=production webpack‘ ]
11 silly lifecycle administration@1.0.0~build: Returned: code: 134 signal: null
12 info lifecycle administration@1.0.0~build: Failed to exec build script
13 verbose stack Error: administration@1.0.0 build: mode=production webpack
13 verbose stack Exit status 134
13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:314:20)
13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:314:20)
13 verbose stack at maybeClose (internal/child_process.js:1022:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
14 verbose pkgid administration@1.0.0
15 verbose cwd /some/folder/development
16 verbose Linux 5.4.0
17 verbose argv „/usr/bin/node“ „/usr/bin/npm“ „run“ „–prefix“ „vendor/shopware/platform/src/Administration/Resources/app/administration/“ „build“
18 verbose node v12.22.7
19 verbose npm v6.14.15
20 error code ELIFECYCLE
21 error errno 134
22 error administration@1.0.0 build: mode=production webpack
22 error Exit status 134
23 error Failed at the administration@1.0.0 build script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 134, true ]
Systemumgebung
Betriebssystem: Ubuntu 20.04 LTS
PHP: 7.4.3
node: 12.22.7
npm: 6.14.15
Kann mir da jemand weiterhelfen? ![]()
