ich versuche über ./bin/build-administration.sh (arbeite leider am Production Template) die Administration neu zu bauen um bei meinem Plugin die public Dateien generieren zu lassen. Leider bekomme ich immer diverse Fehlermeldungen. Hier mein Fehler Log.
0 verbose cli /usr/home/bsadmin/.linuxbrew/Cellar/node/18.0.0/bin/node /usr/home/bsadmin/.linuxbrew/bin/npm
1 info using npm@8.8.0
2 info using node@v18.0.0
3 timing npm:load:whichnode Completed in 0ms
4 timing config:load:defaults Completed in 2ms
5 timing config:load:file:/usr/home/bsadmin/.linuxbrew/lib/node_modules/npm/npmrc Completed in 3ms
6 timing config:load:builtin Completed in 3ms
7 timing config:load:cli Completed in 3ms
8 timing config:load:env Completed in 0ms
9 timing config:load:file:/usr/www/users/bsadmin/battlestore_live/custom/plugins/SwagExtensionStore/src/Resources/app/administration/.npmrc Completed in 1ms
10 timing config:load:project Completed in 1ms
11 timing config:load:file:/usr/home/bsadmin/.npmrc Completed in 2ms
12 timing config:load:user Completed in 2ms
13 timing config:load:file:/usr/www/users/bsadmin/battlestore_live/custom/plugins/SwagExtensionStore/src/Resources/app/administration/etc/npmrc Completed in 0ms
14 timing config:load:global Completed in 0ms
15 timing config:load:validate Completed in 1ms
16 timing config:load:credentials Completed in 1ms
17 timing config:load:setEnvs Completed in 1ms
18 timing config:load Completed in 14ms
19 timing npm:load:configload Completed in 14ms
20 timing npm:load:mkdirpcache Completed in 1ms
21 timing npm:load:mkdirplogs Completed in 0ms
22 verbose title npm clean-install
23 verbose argv "clean-install" "--prefix" "custom/plugins/SwagExtensionStore/src/Resources/app/administration"
24 timing npm:load:setTitle Completed in 1ms
25 timing config:load:flatten Completed in 3ms
26 timing npm:load:display Completed in 6ms
27 verbose logfile logs-max:10 dir:/usr/home/bsadmin/.npm/_logs
28 verbose logfile /usr/home/bsadmin/.npm/_logs/2022-05-27T19_55_41_271Z-debug-0.log
29 timing npm:load:logFile Completed in 5ms
30 timing npm:load:timers Completed in 0ms
31 timing npm:load:configScope Completed in 0ms
32 timing npm:load Completed in 28ms
33 timing arborist:ctor Completed in 0ms
34 silly logfile start cleaning logs, removing 1 files
35 timing npm-ci:rm Completed in 4ms
36 silly logfile done cleaning log files
37 timing idealTree:init Completed in 5ms
38 timing idealTree:userRequests Completed in 0ms
39 silly idealTree buildDeps
40 timing idealTree:#root Completed in 0ms
41 silly fetch manifest webpack@>=1.11.0
42 http fetch GET 200 https://registry.npmjs.org/webpack 104ms (cache revalidated)
43 silly placeDep ROOT webpack@5.72.1 OK for: eslint-import-resolver-webpack@0.11.1 want: >=1.11.0
44 silly fetch manifest @types/eslint-scope@^3.7.3
45 silly fetch manifest @types/estree@^0.0.51
46 silly fetch manifest @webassemblyjs/ast@1.11.1
47 silly fetch manifest @webassemblyjs/wasm-edit@1.11.1
48 silly fetch manifest @webassemblyjs/wasm-parser@1.11.1
49 silly fetch manifest acorn@^8.4.1
50 silly fetch manifest acorn-import-assertions@^1.7.6
51 silly fetch manifest chrome-trace-event@^1.0.2
52 silly fetch manifest enhanced-resolve@^5.9.3
53 silly fetch manifest es-module-lexer@^0.9.0
54 silly fetch manifest eslint-scope@5.1.1
55 silly fetch manifest glob-to-regexp@^0.4.1
56 silly fetch manifest graceful-fs@^4.2.9
57 silly fetch manifest loader-runner@^4.2.0
58 silly fetch manifest neo-async@^2.6.2
59 silly fetch manifest schema-utils@^3.1.0
60 silly fetch manifest tapable@^2.1.1
61 silly fetch manifest terser-webpack-plugin@^5.1.3
62 silly fetch manifest watchpack@^2.3.1
63 silly fetch manifest webpack-sources@^3.2.3
64 http fetch GET 200 https://registry.npmjs.org/@types%2feslint-scope 76ms (cache revalidated)
65 http fetch GET 200 https://registry.npmjs.org/acorn-import-assertions 105ms (cache revalidated)
66 http fetch GET 200 https://registry.npmjs.org/eslint-scope 102ms (cache revalidated)
67 http fetch GET 200 https://registry.npmjs.org/es-module-lexer 104ms (cache revalidated)
68 http fetch GET 200 https://registry.npmjs.org/neo-async 105ms (cache revalidated)
69 http fetch GET 200 https://registry.npmjs.org/tapable 107ms (cache revalidated)
70 http fetch GET 200 https://registry.npmjs.org/acorn 115ms (cache revalidated)
71 http fetch GET 200 https://registry.npmjs.org/chrome-trace-event 118ms (cache revalidated)
72 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fwasm-parser 122ms (cache revalidated)
73 http fetch GET 200 https://registry.npmjs.org/schema-utils 118ms (cache revalidated)
74 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fwasm-edit 127ms (cache revalidated)
75 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fast 131ms (cache revalidated)
76 http fetch GET 200 https://registry.npmjs.org/@types%2festree 132ms (cache revalidated)
77 http fetch GET 200 https://registry.npmjs.org/graceful-fs 130ms (cache revalidated)
78 http fetch GET 200 https://registry.npmjs.org/terser-webpack-plugin 129ms (cache revalidated)
79 http fetch GET 200 https://registry.npmjs.org/glob-to-regexp 133ms (cache revalidated)
80 http fetch GET 200 https://registry.npmjs.org/webpack-sources 130ms (cache revalidated)
81 http fetch GET 200 https://registry.npmjs.org/loader-runner 133ms (cache revalidated)
82 http fetch GET 200 https://registry.npmjs.org/watchpack 132ms (cache revalidated)
83 http fetch GET 200 https://registry.npmjs.org/enhanced-resolve 766ms (cache revalidated)
84 timing idealTree:node_modules/eslint-import-resolver-webpack Completed in 904ms
85 silly fetch manifest typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta
86 http fetch GET 200 https://registry.npmjs.org/typescript 201ms (cache updated)
87 silly placeDep ROOT typescript@4.7.2 OK for: tsutils@3.20.0 want: >=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta
88 timing idealTree:node_modules/tsutils Completed in 243ms
89 timing idealTree:node_modules/typescript Completed in 0ms
90 silly fetch manifest webpack@^5.1.0
91 silly placeDep ROOT @types/eslint-scope@3.7.3 OK for: webpack@5.72.1 want: ^3.7.3
92 silly placeDep ROOT @types/estree@0.0.51 OK for: webpack@5.72.1 want: ^0.0.51
93 silly placeDep ROOT @webassemblyjs/ast@1.11.1 OK for: webpack@5.72.1 want: 1.11.1
94 silly placeDep ROOT @webassemblyjs/wasm-edit@1.11.1 OK for: webpack@5.72.1 want: 1.11.1
95 silly placeDep ROOT @webassemblyjs/wasm-parser@1.11.1 OK for: webpack@5.72.1 want: 1.11.1
96 silly placeDep node_modules/webpack acorn@8.7.1 OK for: webpack@5.72.1 want: ^8.4.1
97 silly placeDep node_modules/webpack acorn-import-assertions@1.8.0 OK for: webpack@5.72.1 want: ^1.7.6
98 silly placeDep ROOT chrome-trace-event@1.0.3 OK for: webpack@5.72.1 want: ^1.0.2
99 silly placeDep node_modules/webpack enhanced-resolve@5.9.3 OK for: webpack@5.72.1 want: ^5.9.3
100 silly placeDep ROOT es-module-lexer@0.9.3 OK for: webpack@5.72.1 want: ^0.9.0
101 silly placeDep node_modules/webpack eslint-scope@5.1.1 OK for: webpack@5.72.1 want: 5.1.1
102 silly placeDep ROOT glob-to-regexp@0.4.1 OK for: webpack@5.72.1 want: ^0.4.1
103 silly placeDep ROOT graceful-fs@4.2.10 REPLACE for: webpack@5.72.1 want: ^4.2.9
104 silly placeDep ROOT loader-runner@4.3.0 OK for: webpack@5.72.1 want: ^4.2.0
105 silly placeDep ROOT neo-async@2.6.2 OK for: webpack@5.72.1 want: ^2.6.2
106 silly placeDep ROOT schema-utils@3.1.1 OK for: webpack@5.72.1 want: ^3.1.0
107 silly placeDep node_modules/webpack tapable@2.2.1 OK for: webpack@5.72.1 want: ^2.1.1
108 silly placeDep ROOT terser-webpack-plugin@5.3.1 OK for: webpack@5.72.1 want: ^5.1.3
109 silly placeDep ROOT watchpack@2.3.1 OK for: webpack@5.72.1 want: ^2.3.1
110 silly placeDep ROOT webpack-sources@3.2.3 OK for: webpack@5.72.1 want: ^3.2.3
111 silly fetch manifest @types/eslint@*
112 silly fetch manifest @webassemblyjs/helper-numbers@1.11.1
113 silly fetch manifest @webassemblyjs/helper-wasm-bytecode@1.11.1
114 silly fetch manifest @webassemblyjs/helper-buffer@1.11.1
115 silly fetch manifest @webassemblyjs/helper-wasm-section@1.11.1
116 silly fetch manifest @webassemblyjs/wasm-gen@1.11.1
117 silly fetch manifest @webassemblyjs/wasm-opt@1.11.1
118 silly fetch manifest @webassemblyjs/wast-printer@1.11.1
119 silly fetch manifest @webassemblyjs/helper-api-error@1.11.1
120 silly fetch manifest @webassemblyjs/ieee754@1.11.1
121 silly fetch manifest @webassemblyjs/leb128@1.11.1
122 silly fetch manifest @webassemblyjs/utf8@1.11.1
123 silly fetch manifest @types/json-schema@^7.0.8
124 silly fetch manifest ajv-keywords@^3.5.2
125 silly fetch manifest jest-worker@^27.4.5
126 silly fetch manifest serialize-javascript@^6.0.0
127 silly fetch manifest source-map@^0.6.1
128 silly fetch manifest terser@^5.7.2
129 http fetch GET 200 https://registry.npmjs.org/source-map 61ms (cache revalidated)
130 http fetch GET 200 https://registry.npmjs.org/ajv-keywords 65ms (cache revalidated)
131 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fhelper-buffer 76ms (cache revalidated)
132 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fwast-printer 77ms (cache revalidated)
133 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fieee754 77ms (cache revalidated)
134 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fwasm-opt 90ms (cache revalidated)
135 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fhelper-api-error 94ms (cache revalidated)
136 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fhelper-wasm-bytecode 106ms (cache revalidated)
137 http fetch GET 200 https://registry.npmjs.org/@types%2fjson-schema 98ms (cache revalidated)
138 http fetch GET 200 https://registry.npmjs.org/@types%2feslint 109ms (cache revalidated)
139 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fleb128 105ms (cache revalidated)
140 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fhelper-numbers 111ms (cache revalidated)
141 http fetch GET 200 https://registry.npmjs.org/jest-worker 101ms (cache revalidated)
142 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fhelper-wasm-section 114ms (cache revalidated)
143 http fetch GET 200 https://registry.npmjs.org/serialize-javascript 107ms (cache revalidated)
144 http fetch GET 200 https://registry.npmjs.org/terser 107ms (cache revalidated)
145 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2fwasm-gen 120ms (cache revalidated)
146 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2futf8 714ms (cache revalidated)
147 timing idealTree:node_modules/webpack Completed in 777ms
148 silly placeDep ROOT @types/eslint@8.4.2 OK for: @types/eslint-scope@3.7.3 want: *
149 timing idealTree:node_modules/@types/eslint-scope Completed in 7ms
150 timing idealTree:node_modules/@types/eslint Completed in 0ms
151 timing idealTree:node_modules/@types/estree Completed in 0ms
152 silly placeDep ROOT @webassemblyjs/helper-numbers@1.11.1 OK for: @webassemblyjs/ast@1.11.1 want: 1.11.1
153 silly placeDep ROOT @webassemblyjs/helper-wasm-bytecode@1.11.1 OK for: @webassemblyjs/ast@1.11.1 want: 1.11.1
154 silly fetch manifest @webassemblyjs/floating-point-hex-parser@1.11.1
155 silly fetch manifest @xtuc/long@4.2.2
156 http fetch GET 200 https://registry.npmjs.org/@webassemblyjs%2ffloating-point-hex-parser 58ms (cache revalidated)
157 http fetch GET 200 https://registry.npmjs.org/@xtuc%2flong 82ms (cache revalidated)
158 timing idealTree:node_modules/@webassemblyjs/ast Completed in 106ms
159 silly placeDep ROOT @webassemblyjs/floating-point-hex-parser@1.11.1 OK for: @webassemblyjs/helper-numbers@1.11.1 want: 1.11.1
160 silly placeDep ROOT @webassemblyjs/helper-api-error@1.11.1 OK for: @webassemblyjs/helper-numbers@1.11.1 want: 1.11.1
161 silly placeDep ROOT @xtuc/long@4.2.2 OK for: @webassemblyjs/helper-numbers@1.11.1 want: 4.2.2
162 timing idealTree:node_modules/@webassemblyjs/helper-numbers Completed in 13ms
163 timing idealTree:node_modules/@webassemblyjs/floating-point-hex-parser Completed in 0ms
164 timing idealTree:node_modules/@webassemblyjs/helper-api-error Completed in 0ms
165 timing idealTree:node_modules/@webassemblyjs/helper-wasm-bytecode Completed in 0ms
166 silly placeDep ROOT @webassemblyjs/helper-buffer@1.11.1 OK for: @webassemblyjs/wasm-edit@1.11.1 want: 1.11.1
167 silly placeDep ROOT @webassemblyjs/helper-wasm-section@1.11.1 OK for: @webassemblyjs/wasm-edit@1.11.1 want: 1.11.1
168 silly placeDep ROOT @webassemblyjs/wasm-gen@1.11.1 OK for: @webassemblyjs/wasm-edit@1.11.1 want: 1.11.1
169 silly placeDep ROOT @webassemblyjs/wasm-opt@1.11.1 OK for: @webassemblyjs/wasm-edit@1.11.1 want: 1.11.1
170 silly placeDep ROOT @webassemblyjs/wast-printer@1.11.1 OK for: @webassemblyjs/wasm-edit@1.11.1 want: 1.11.1
171 timing idealTree:node_modules/@webassemblyjs/wasm-edit Completed in 14ms
172 timing idealTree:node_modules/@webassemblyjs/helper-buffer Completed in 0ms
173 timing idealTree:node_modules/@webassemblyjs/helper-wasm-section Completed in 0ms
174 silly placeDep ROOT @webassemblyjs/ieee754@1.11.1 OK for: @webassemblyjs/wasm-gen@1.11.1 want: 1.11.1
175 silly placeDep ROOT @webassemblyjs/leb128@1.11.1 OK for: @webassemblyjs/wasm-gen@1.11.1 want: 1.11.1
176 silly placeDep ROOT @webassemblyjs/utf8@1.11.1 OK for: @webassemblyjs/wasm-gen@1.11.1 want: 1.11.1
177 silly fetch manifest @xtuc/ieee754@^1.2.0
178 http fetch GET 200 https://registry.npmjs.org/@xtuc%2fieee754 94ms (cache revalidated)
179 timing idealTree:node_modules/@webassemblyjs/wasm-gen Completed in 102ms
180 silly placeDep ROOT @xtuc/ieee754@1.2.0 OK for: @webassemblyjs/ieee754@1.11.1 want: ^1.2.0
181 timing idealTree:node_modules/@webassemblyjs/ieee754 Completed in 5ms
182 timing idealTree:node_modules/@webassemblyjs/leb128 Completed in 0ms
183 timing idealTree:node_modules/@webassemblyjs/utf8 Completed in 0ms
184 timing idealTree:node_modules/@webassemblyjs/wasm-opt Completed in 0ms
185 timing idealTree:node_modules/@webassemblyjs/wasm-parser Completed in 0ms
186 timing idealTree:node_modules/@webassemblyjs/wast-printer Completed in 0ms
187 timing idealTree:node_modules/@xtuc/ieee754 Completed in 0ms
188 timing idealTree:node_modules/@xtuc/long Completed in 0ms
189 timing idealTree:node_modules/chrome-trace-event Completed in 0ms
190 timing idealTree:node_modules/es-module-lexer Completed in 0ms
191 timing idealTree:node_modules/glob-to-regexp Completed in 0ms
192 timing idealTree:node_modules/graceful-fs Completed in 0ms
193 timing idealTree:node_modules/loader-runner Completed in 1ms
194 timing idealTree:node_modules/neo-async Completed in 0ms
195 silly fetch manifest ajv@^6.12.5
196 http fetch GET 200 https://registry.npmjs.org/ajv 31ms (cache revalidated)
197 silly placeDep ROOT @types/json-schema@7.0.11 REPLACE for: schema-utils@3.1.1 want: ^7.0.8
198 silly placeDep ROOT ajv-keywords@3.5.2 OK for: schema-utils@3.1.1 want: ^3.5.2
199 timing idealTree:node_modules/schema-utils Completed in 49ms
200 timing idealTree:node_modules/@types/json-schema Completed in 0ms
201 timing idealTree:node_modules/ajv-keywords Completed in 0ms
202 silly placeDep node_modules/terser-webpack-plugin jest-worker@27.5.1 OK for: terser-webpack-plugin@5.3.1 want: ^27.4.5
203 silly placeDep ROOT serialize-javascript@6.0.0 OK for: terser-webpack-plugin@5.3.1 want: ^6.0.0
204 silly placeDep node_modules/terser-webpack-plugin source-map@0.6.1 OK for: terser-webpack-plugin@5.3.1 want: ^0.6.1
205 silly placeDep ROOT terser@5.13.1 OK for: terser-webpack-plugin@5.3.1 want: ^5.7.2
206 silly fetch manifest supports-color@^8.0.0
207 silly fetch manifest acorn@^8.5.0
208 silly fetch manifest source-map@~0.8.0-beta.0
209 silly fetch manifest source-map-support@~0.5.20
210 http fetch GET 200 https://registry.npmjs.org/supports-color 36ms (cache revalidated)
211 http fetch GET 200 https://registry.npmjs.org/source-map-support 40ms (cache revalidated)
212 timing idealTree:node_modules/terser-webpack-plugin Completed in 54ms
213 timing idealTree:node_modules/serialize-javascript Completed in 0ms
214 silly placeDep node_modules/terser acorn@8.7.1 OK for: terser@5.13.1 want: ^8.5.0
215 silly placeDep node_modules/terser source-map@0.8.0-beta.0 OK for: terser@5.13.1 want: ~0.8.0-beta.0
216 silly placeDep ROOT source-map-support@0.5.21 REPLACE for: terser@5.13.1 want: ~0.5.20
217 silly fetch manifest whatwg-url@^7.0.0
218 http fetch GET 200 https://registry.npmjs.org/whatwg-url 41ms (cache revalidated)
219 timing idealTree:node_modules/terser Completed in 51ms
220 timing idealTree:node_modules/source-map-support Completed in 0ms
221 timing idealTree:node_modules/watchpack Completed in 0ms
222 timing idealTree:node_modules/webpack-sources Completed in 0ms
223 silly placeDep node_modules/terser-webpack-plugin supports-color@8.1.1 OK for: jest-worker@27.5.1 want: ^8.0.0
224 silly fetch manifest has-flag@^4.0.0
225 http fetch GET 200 https://registry.npmjs.org/has-flag 34ms (cache revalidated)
226 timing idealTree:node_modules/terser-webpack-plugin/node_modules/jest-worker Completed in 37ms
227 timing idealTree:node_modules/terser-webpack-plugin/node_modules/source-map Completed in 0ms
228 silly placeDep node_modules/terser-webpack-plugin has-flag@4.0.0 OK for: supports-color@8.1.1 want: ^4.0.0
229 timing idealTree:node_modules/terser-webpack-plugin/node_modules/supports-color Completed in 4ms
230 timing idealTree:node_modules/terser-webpack-plugin/node_modules/has-flag Completed in 0ms
231 timing idealTree:node_modules/terser/node_modules/acorn Completed in 0ms
232 silly placeDep node_modules/terser whatwg-url@7.1.0 OK for: source-map@0.8.0-beta.0 want: ^7.0.0
233 silly fetch manifest tr46@^1.0.1
234 silly fetch manifest webidl-conversions@^4.0.2
235 http fetch GET 200 https://registry.npmjs.org/webidl-conversions 41ms (cache revalidated)
236 http fetch GET 200 https://registry.npmjs.org/tr46 51ms (cache revalidated)
237 timing idealTree:node_modules/terser/node_modules/source-map Completed in 61ms
238 silly placeDep node_modules/terser tr46@1.0.1 OK for: whatwg-url@7.1.0 want: ^1.0.1
239 silly placeDep node_modules/terser webidl-conversions@4.0.2 OK for: whatwg-url@7.1.0 want: ^4.0.2
240 timing idealTree:node_modules/terser/node_modules/whatwg-url Completed in 8ms
241 timing idealTree:node_modules/terser/node_modules/tr46 Completed in 0ms
242 timing idealTree:node_modules/terser/node_modules/webidl-conversions Completed in 0ms
243 timing idealTree:node_modules/webpack/node_modules/acorn Completed in 0ms
244 timing idealTree:node_modules/webpack/node_modules/acorn-import-assertions Completed in 0ms
245 timing idealTree:node_modules/webpack/node_modules/enhanced-resolve Completed in 0ms
246 timing idealTree:node_modules/webpack/node_modules/eslint-scope Completed in 1ms
247 timing idealTree:node_modules/webpack/node_modules/tapable Completed in 0ms
248 timing idealTree:internal-rules Completed in 0ms
249 timing idealTree:buildDeps Completed in 2452ms
250 timing idealTree:fixDepFlags Completed in 24ms
251 timing idealTree Completed in 2511ms
252 timing command:clean-install Completed in 3172ms
253 verbose stack Error: `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
253 verbose stack
253 verbose stack Missing: webpack@5.72.1 from lock file
253 verbose stack Missing: typescript@4.7.2 from lock file
253 verbose stack Missing: @types/eslint-scope@3.7.3 from lock file
253 verbose stack Missing: @types/estree@0.0.51 from lock file
253 verbose stack Missing: @webassemblyjs/ast@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/wasm-edit@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/wasm-parser@1.11.1 from lock file
253 verbose stack Missing: acorn@8.7.1 from lock file
253 verbose stack Missing: acorn-import-assertions@1.8.0 from lock file
253 verbose stack Missing: chrome-trace-event@1.0.3 from lock file
253 verbose stack Missing: enhanced-resolve@5.9.3 from lock file
253 verbose stack Missing: es-module-lexer@0.9.3 from lock file
253 verbose stack Missing: eslint-scope@5.1.1 from lock file
253 verbose stack Missing: glob-to-regexp@0.4.1 from lock file
253 verbose stack Invalid: lock file's graceful-fs@4.2.6 does not satisfy graceful-fs@4.2.10
253 verbose stack Missing: loader-runner@4.3.0 from lock file
253 verbose stack Missing: neo-async@2.6.2 from lock file
253 verbose stack Missing: schema-utils@3.1.1 from lock file
253 verbose stack Missing: tapable@2.2.1 from lock file
253 verbose stack Missing: terser-webpack-plugin@5.3.1 from lock file
253 verbose stack Missing: watchpack@2.3.1 from lock file
253 verbose stack Missing: webpack-sources@3.2.3 from lock file
253 verbose stack Missing: @types/eslint@8.4.2 from lock file
253 verbose stack Missing: @webassemblyjs/helper-numbers@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/helper-wasm-bytecode@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/floating-point-hex-parser@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/helper-api-error@1.11.1 from lock file
253 verbose stack Missing: @xtuc/long@4.2.2 from lock file
253 verbose stack Missing: @webassemblyjs/helper-buffer@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/helper-wasm-section@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/wasm-gen@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/wasm-opt@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/wast-printer@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/ieee754@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/leb128@1.11.1 from lock file
253 verbose stack Missing: @webassemblyjs/utf8@1.11.1 from lock file
253 verbose stack Missing: @xtuc/ieee754@1.2.0 from lock file
253 verbose stack Invalid: lock file's @types/json-schema@7.0.7 does not satisfy @types/json-schema@7.0.11
253 verbose stack Missing: ajv-keywords@3.5.2 from lock file
253 verbose stack Missing: jest-worker@27.5.1 from lock file
253 verbose stack Missing: serialize-javascript@6.0.0 from lock file
253 verbose stack Missing: source-map@0.6.1 from lock file
253 verbose stack Missing: terser@5.13.1 from lock file
253 verbose stack Missing: source-map@0.8.0-beta.0 from lock file
253 verbose stack Invalid: lock file's source-map-support@0.5.19 does not satisfy source-map-support@0.5.21
253 verbose stack Missing: supports-color@8.1.1 from lock file
253 verbose stack Missing: has-flag@4.0.0 from lock file
253 verbose stack Missing: whatwg-url@7.1.0 from lock file
253 verbose stack Missing: tr46@1.0.1 from lock file
253 verbose stack Missing: webidl-conversions@4.0.2 from lock file
253 verbose stack
253 verbose stack     at CI.exec (/usr/home/bsadmin/.linuxbrew/lib/node_modules/npm/lib/commands/ci.js:73:13)
253 verbose stack     at async module.exports (/usr/home/bsadmin/.linuxbrew/lib/node_modules/npm/lib/cli.js:78:5)
254 verbose cwd /usr/www/users/bsadmin/battlestore_live
255 verbose Linux 5.10.0-14-amd64
256 verbose node v18.0.0
257 verbose npm  v8.8.0
258 error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
258 error
258 error Missing: webpack@5.72.1 from lock file
258 error Missing: typescript@4.7.2 from lock file
258 error Missing: @types/eslint-scope@3.7.3 from lock file
258 error Missing: @types/estree@0.0.51 from lock file
258 error Missing: @webassemblyjs/ast@1.11.1 from lock file
258 error Missing: @webassemblyjs/wasm-edit@1.11.1 from lock file
258 error Missing: @webassemblyjs/wasm-parser@1.11.1 from lock file
258 error Missing: acorn@8.7.1 from lock file
258 error Missing: acorn-import-assertions@1.8.0 from lock file
258 error Missing: chrome-trace-event@1.0.3 from lock file
258 error Missing: enhanced-resolve@5.9.3 from lock file
258 error Missing: es-module-lexer@0.9.3 from lock file
258 error Missing: eslint-scope@5.1.1 from lock file
258 error Missing: glob-to-regexp@0.4.1 from lock file
258 error Invalid: lock file's graceful-fs@4.2.6 does not satisfy graceful-fs@4.2.10
258 error Missing: loader-runner@4.3.0 from lock file
258 error Missing: neo-async@2.6.2 from lock file
258 error Missing: schema-utils@3.1.1 from lock file
258 error Missing: tapable@2.2.1 from lock file
258 error Missing: terser-webpack-plugin@5.3.1 from lock file
258 error Missing: watchpack@2.3.1 from lock file
258 error Missing: webpack-sources@3.2.3 from lock file
258 error Missing: @types/eslint@8.4.2 from lock file
258 error Missing: @webassemblyjs/helper-numbers@1.11.1 from lock file
258 error Missing: @webassemblyjs/helper-wasm-bytecode@1.11.1 from lock file
258 error Missing: @webassemblyjs/floating-point-hex-parser@1.11.1 from lock file
258 error Missing: @webassemblyjs/helper-api-error@1.11.1 from lock file
258 error Missing: @xtuc/long@4.2.2 from lock file
258 error Missing: @webassemblyjs/helper-buffer@1.11.1 from lock file
258 error Missing: @webassemblyjs/helper-wasm-section@1.11.1 from lock file
258 error Missing: @webassemblyjs/wasm-gen@1.11.1 from lock file
258 error Missing: @webassemblyjs/wasm-opt@1.11.1 from lock file
258 error Missing: @webassemblyjs/wast-printer@1.11.1 from lock file
258 error Missing: @webassemblyjs/ieee754@1.11.1 from lock file
258 error Missing: @webassemblyjs/leb128@1.11.1 from lock file
258 error Missing: @webassemblyjs/utf8@1.11.1 from lock file
258 error Missing: @xtuc/ieee754@1.2.0 from lock file
258 error Invalid: lock file's @types/json-schema@7.0.7 does not satisfy @types/json-schema@7.0.11
258 error Missing: ajv-keywords@3.5.2 from lock file
258 error Missing: jest-worker@27.5.1 from lock file
258 error Missing: serialize-javascript@6.0.0 from lock file
258 error Missing: source-map@0.6.1 from lock file
258 error Missing: terser@5.13.1 from lock file
258 error Missing: source-map@0.8.0-beta.0 from lock file
258 error Invalid: lock file's source-map-support@0.5.19 does not satisfy source-map-support@0.5.21
258 error Missing: supports-color@8.1.1 from lock file
258 error Missing: has-flag@4.0.0 from lock file
258 error Missing: whatwg-url@7.1.0 from lock file
258 error Missing: tr46@1.0.1 from lock file
258 error Missing: webidl-conversions@4.0.2 from lock file
258 error
259 verbose exit 1
260 timing npm Completed in 3307ms
261 verbose code 1
262 error A complete log of this run can be found in:
262 error     /usr/home/bsadmin/.npm/_logs/2022-05-27T19_55_41_271Z-debug-0.log
Jemand einen Rat oder Tipp für mich?
Lg Alex
