Nach dem Update von Shopware 6.6.5 auf 6.6.7 funktioniert die build-administration nicht mehr.
NPM V.20
Node V.10
Ich erhalte diesen Fehler:
sudo bin/build-administration.sh
[OK] Dumped plugin configuration.
[OK] Successfully dumped js feature configuration
npm warn config production Use `--omit=dev` instead.
npm warn deprecated @humanwhocodes/config-array@0.5.0: Use @eslint/config-array instead
npm warn deprecated @humanwhocodes/object-schema@1.2.1: Use @eslint/object-schema instead
> administration@1.0.0 preinstall
> node ./scripts/validate-package-json/index.mjs
> administration@1.0.0 postinstall
> patch-package
patch-package 6.5.1
Applying patches...
babel-plugin-require-context-hook@1.0.0 ✔
eslint@8.36.0 ✔
Skipping dev-only eslint-plugin-vue@9.14.1 ✔
inter-ui@3.19.3 ✔
Skipping dev-only jest-expect-message@1.1.3 ✔
Skipping dev-only vue-eslint-parser@9.3.1 ✔
added 18 packages in 2s
Writing definition to file ...
Done!
> administration@1.0.0 convert-entity-schema
> ts-node --transpileOnly ./scripts/entitySchemaConverter/convert-schema.ts
> administration@1.0.0 build
> mode=production node --no-deprecation ./node_modules/webpack/bin/webpack.js --config webpack.config.js
# Compiling with Webpack configuration
# Production mode is activated 🚀
# Plugin "Storefront": Injected successfully
# Plugin "DoopAppsTheme": Injected successfully
● Doop-apps-theme █████████████████████████ sealing (94%)
after seal
● Shopware 6 Admin █████████████████████████ sealing (92%) asset processing
TerserPlugin
✖ Storefront
Compiled with some errors in 124.24ms
✖ Doop-apps-theme
Compiled with some errors in 125.65ms
TerserPlugin
✖ Storefront
✖ Doop-apps-theme
✖ Shopware 6 Admin
Compiled with some errors in 145.25ms
✖ Storefront
112 assets
4 modules
ERROR in ./src/index.ts
Module build failed (from ./node_modules/swc-loader/src/index.js):
Error: Bindings not found.
at Compiler.<anonymous> (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:228:19)
at Generator.next (<anonymous>)
at /Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:34:71
at new Promise (<anonymous>)
at __awaiter (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:30:12)
at Compiler.transform (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:205:16)
at Object.transform (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:347:21)
at Object.<anonymous> (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/swc-loader/src/index.js:97:21)
ERROR in static/js/app.js
static/js/app.js from Terser plugin
Bindings not found.
at Compiler.<anonymous> (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:105:19)
at Compiler.minify (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:98:16)
at Object.<anonymous> (/Applications/MAMP/htdocs/SternOrientalEC2/vendor/shopware/administration/Resources/app/administration/node_modules/@swc/core/index.js:368:25)
webpack 5.88.2 compiled with 2 errors in 159 ms
1 asset
4 modules
ERROR in ../../../../storefront/Resources/app/administration/src/main.js
ERROR in static/js/storefront.js
static/js/storefront.js from Terser plugin
Bindings not found.
webpack 5.88.2 compiled with 2 errors in 120 ms
1 asset
4 modules
ERROR in ../../../../../../custom/plugins/DoopAppsTheme/src/Resources/app/administration/src/main.js
ERROR in static/js/doop-apps-theme.js
static/js/doop-apps-theme.js from Terser plugin
Bindings not found.
webpack 5.88.2 compiled with 2 errors in 123 ms
Leider hab ich bis jetzt keine Lösung gefunden. Ich freue mich auf Ihre Hilfe!
