Hallo an alle ich habe beim installieren folgende Fehlermeldung im Abschnitt „Datenbank Import“: Error Received an error message. URL: importSnippets?offset=550&totalCount=1271 Message: Internal Server Error Please try to fix this error and restart the update. Response Slim Application Error The application could not run because of the following error: Details Type: RuntimeException Message: Identifier DB not initialized yet File: /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/install/src/ContainerProvider.php Line: 160 Trace #0 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container)) #1 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/install/src/app.php(550): Pimple\Container->offsetGet(‚db‘) #2 [internal function]: {closure}() #3 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #4 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #5 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #6 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #7 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #8 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #9 /home/ruccola/web/test.st-sign.at/htdocs/Pichlshop/recovery/install/index.php(74): Slim\Slim->run() #10 {main} Passwörter und Zugangsdaten stimmen alle - was hat dies zu bedeuten und wie löse ich das? Vielen Dank im Voraus!
Hallo Ruccola, ich hatte an der Stelle bisher auch schon 2x einen Fehler. Ich habe es einfach neu versucht und dann hat alles geklappt. Gruß
[quote=“Shopware Freelancer”]Hallo Ruccola, ich hatte an der Stelle bisher auch schon 2x einen Fehler. Ich habe es einfach neu versucht und dann hat alles geklappt. Gruß[/quote] bei mir genau gleich, jetzt passt es - tread kann geschlossen werden
