How to remove the /public/ from the site adress?
Hi all,
i am new here. I decided to migrate to shopware from another cart but…an eternal struggle to install.
My current problem is that i need to open my store at his root adress as: www.mystore.ro
but after the instalation the store open only on www.mystore.ro/public
I need to remove that /public/ is essential because i need to migrate and i have already indexed links for my products.
I readed already and tested all on the forums including httpacces …no chance, maybe there are some solutions on german but the translation in poor. I also made the modifications in Sales Channels
Also i saw some shopware store with root adress only
Thank you all
Dragan
Your domain has to point to the /public folder. That is it.
When you tell that HAS TO …it mean that there is no way to access my site in its simple form www.mysite.com ? And i must accept the mysite. com / public/ ?
I saw same succes sites with shopware and all had mysite.com and not mysite . com/public/
Thank you for the reply
No, no, no :joy:
Your domain points to a folder on your server, e.g., httpdocs/shopware
You have to change that to, e.g., httpdocs/shopware/public
Then the /public part in your domain will disappear.
Thank you, but where to change?
i tried almost all places including in cpanel and also in shopware. Bun no chance
It has nothing to do with Shopware.
It is your domain/server configuration. If it is not possible to change the directory, you can try to work with a symlink.
Thank you very much
i will try
Regards
:slight_smile:
