Hallo zusammen, im Einsatz ist Release 3.5.5 Rev.7126 ein. Mit Einrichtung eines Subshops in englischer Sprache und bei Einsatz von „Individuellen Optionen“ erscheint nachfolgende Fehlermeldung: Ups! An error has occurred! The following hints should help you. SQLSTATE[42S22]: Column not found: 1054 Unknown column ‚‘ in ‚field list‘ in Vendor/Zend/library/Zend/Db/Statement/Pdo.php on line 234 Stack trace: #0 Vendor/Zend/library/Zend/Db/Statement.php(300): Zend_Db_Statement_Pdo->_execute(Array) #1 Vendor/Zend/library/Zend/Db/Adapter/Abstract.php(479): Zend_Db_Statement->execute(Array)http://forum.shopware.de/posting.php?mode=post&f=13&sid=1ff5ddc8d6be1f04bad2561e7fb37a22# #2 Vendor/Zend/library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(’? ??SELECT ...', Array) #3 Enlight/Components/Db/Adapter/Pdo/Mysql.php(50): Zend_Db_Adapter_Pdo_Abstract-\>query('? ??SELECT …’, Array) #4 Vendor/Zend/library/Zend/Db/Adapter/Abstract.php(825): Enlight_Components_Db_Adapter_Pdo_Mysql->query(’? ??SELECT ...', Array) #5 Shopware/Plugins/Community/Frontend/SwagCustomizing/Bootstrap.php(583): Zend_Db_Adapter_Abstract-\>fetchOne('? ??SELECT …’, Array) #6 Enlight/Event/EventHandler.php(60): Shopware_Plugins_Frontend_SwagCustomizing_Bootstrap::onUpdateBasketArticle(Object(Enlight_Event_EventArgs)) #7 Enlight/Event/EventManager.php(96): Enlight_Event_EventHandler->execute(‚Shopware_Plugin…‘, Object(Enlight_Event_EventArgs)) #8 engine/core/class/sBasket.php(1311): Enlight_Event_EventManager->notifyUntil(Object(Enlight_Event_EventArgs)) #9 engine/core/class/sBasket.php(850): sBasket->sUpdateArticle(‚Shopware_Module…‘, Array) #10 engine/core/class/sAdmin.php(367): sBasket->sGetBasket(‚3009‘, ‚2‘) #11 Shopware/Controllers/Frontend/Checkout.php(889): sAdmin->sGetPaymentMeans() #12 Shopware/Controllers/Frontend/Checkout.php(937): Shopware_Controllers_Frontend_Checkout->getPayments() #13 Shopware/Controllers/Frontend/Checkout.php(71): Shopware_Controllers_Frontend_Checkout->getSelectedPayment() #14 Enlight/Controller/Action.php(70): Shopware_Controllers_Frontend_Checkout->cartAction() #15 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch() #16 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(‚cartAction‘) #17 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #18 Enlight/Application.php(86): Shopware_Bootstrap->run() #19 shopware.php(6): Enlight_Application->run() #20 {main} Wenn dieser Fehler schon mal behandelt worden ist bitte kurze Info. Ansonsten gibt es eine Lösung/Alternative? Danke für Eure Antworten.
Gibt es dazu inzwischen schon eine Lösung? Ich stehe nämlich vor dem selben Problem…
