Hallo
Bei der Installation (kein Update) der 5.2 BETA habe ich folgende Fehlermeldung. Kann jmd mir einen Tip geben?
Bei der Prüfung der Techn. Voraussetzungen ist alles i.o. (grün). Ebenfalls der DB Update läuft problemlos durch.
Slim Application Error
Type: ErrorException
Code: 2
Message: is_file(): open_basedir restriction in effect. File(/var/www/vhosts/allview.ch/httpdocs/shopware52/plugins/.gitkeep/.gitkeep.php) is not within the allowed path(s): (/var/www/vhosts/allview.ch/:/tmp/)
File: /var/www/vhosts/allview.ch/httpdocs/shopware52/engine/Shopware/Kernel.php
Line: 310
Trace
#0 [internal function]: Slim\Slim::handleErrors(2, ‘is_file(): open…’, ‘/var/www/vhosts…’, 310, Array)#1 /var/www/vhosts/allview.ch/httpdocs/shopware52/engine/Shopware/Kernel.php(310): is_file(’/var/www/vhosts…’)#2 /var/www/vhosts/allview.ch/httpdocs/shopware52/engine/Shopware/Kernel.php(270): Shopware\Kernel->initializePlugins()#3 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/install/src/ContainerProvider.php(120): Shopware\Kernel->boot()#4 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#5 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/install/src/ContainerProvider.php(129): Pimple\Container->offsetGet(‘shopware.contai…’)#6 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#7 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/install/src/ContainerProvider.php(144): Pimple\Container->offsetGet(‘shopware.theme_…’)#8 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))#9 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/install/src/app.php(437): Pimple\Container->offsetGet(‘theme.service’)#10 [internal function]: {closure}()#11 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#12 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#13 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#14 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#15 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#16 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#17 /var/www/vhosts/allview.ch/httpdocs/shopware52/recovery/install/index.php(74): Slim\Slim->run()
#18 {main}
