Hallo ich bekomme folgende fehler gemeldet - kann leider damit nichts anfangen - woran liegt es das es nicht weiter geht ?
Slim Application Error
Type: ErrorException
Code: 2
Message: require_once(): open_basedir restriction in effect. File(/var/www/vhosts/hosting129927.a2e16.netcup.net) is not within the allowed path(s): (/var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/:/tmp/:/var/lib/php5/sessions:/var/lib/php/sessions:/var/www/vhosts/hosting129927.a2e16.netcup.net/tmp)
File: /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/phpstan/phpstan-shim/bootstrap.php
Line: 8
Trace
#0 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/phpstan/phpstan-shim/bootstrap.php(8): Slim\Slim::handleErrors(2, 'require_once():...', '/var/www/vhosts...', 8, Array)
#1 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/phpstan/phpstan-shim/bootstrap.php(8): require_once()
#2 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/composer/autoload_real.php(70): require('/var/www/vhosts...')
#3 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/composer/autoload_real.php(60): composerRequireShopware('574b1c4a61c1930...', '/var/www/vhosts...')
#4 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/vendor/autoload.php(7): ComposerAutoloaderInitShopware::getLoader()
#5 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/autoload.php(31): require('/var/www/vhosts...')
#6 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/install/src/ContainerProvider.php(114): require_once('/var/www/vhosts...')
#7 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install\{closure}(Object(Pimple\Container))
#8 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/install/src/ContainerProvider.php(126): Pimple\Container->offsetGet('shopware.contai...')
#9 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install\{closure}(Object(Pimple\Container))
#10 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/install/src/ContainerProvider.php(139): Pimple\Container->offsetGet('shopware.theme_...')
#11 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install\{closure}(Object(Pimple\Container))
#12 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/install/src/app.php(496): Pimple\Container->offsetGet('theme.service')
#13 [internal function]: {closure}()
#14 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#15 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#16 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#17 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#18 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#19 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#20 /var/www/vhosts/hosting129927.a2e16.netcup.net/httpdocs/shopware563/recovery/install/index.php(75): Slim\Slim->run()
#21 {main}
