Fehlermeldung beim Artikel
kann derzeit die Artikel nicht ändern oder neue erstellen. Folgende Fehlermeldung erscheint. Hat jemand eine Idee? Vielen Dank.
An exception occurred while executing ‚INSERT INTO s_articles (main_detail_id, supplierID, taxID, pricegroupID, filtergroupID, configurator_set_id, name, description, description_long, datum, active, pseudosales, topseller, keywords, metaTitle, changetime, pricegroupActive, laststock, crossbundlelook, notification, template, mode, available_from, available_to) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)‘ with params [null, null, null, null, null, null, null, null, null, „2017-07-12“, 0, 0, 0, null, null, „2017-07-12 12:32:16“, 0, 0, false, 0, „“, 0, null, null]: SQLSTATE[23000]: Integrity constraint violation: 1048 Column ‚name‘ cannot be null in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119
Stack trace:
#0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(172): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‚INSERT INTO s_a…‘, Array)
#1 Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(281): Doctrine\DBAL\Statement->execute()
#2 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1018): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->executeInserts()
#3 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(378): Doctrine\ORM\UnitOfWork->executeInserts(Object(Doctrine\ORM\Mapping\ClassMetadata))
#4 vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(356): Doctrine\ORM\UnitOfWork->commit(NULL)
#5 Shopware/Controllers/Backend/Article.php(1382): Doctrine\ORM\EntityManager->flush()
#6 Shopware/Controllers/Backend/Article.php(314): Shopware_Controllers_Backend_Article->saveArticle(Array, Object(Shopware\Models\Article\Article))
#7 Enlight/Controller/Action.php(158): Shopware_Controllers_Backend_Article->saveAction()
#8 Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚saveAction‘)
#9 Enlight/Controller/Front.php(226): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#10 Shopware/Kernel.php(153): Enlight_Controller_Front->dispatch()
#11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#15 shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
Hmmm, ich gehe ja davon aus das die Einträge auch Inhalte hatten. In letzter Zeit ein Update geamcht? Oder Backend-Plugins die zur eingesetzten SW Version nicht kompatible sind?
vielen Dank. Kategorien lassen sich ändern und speichern. Artikel haben Inhalte und können jetzt nicht geändert bzw. gespeichert werden.
Wir haben in der letzten Zeit nur ein Sicherheits-Shopware-Plug In installiert.
Laut dem INSERT sind die Werte alle auf NULL. So ein Effekt kenne ich aus dem Shop gar nicht und wir haben viele. Ich würde mal alle Logs durchgehen und debuggen ob es irgendwo noch Anhaltspunkte gibt.
Fehlermeldungen in Shopware debuggen - Doku - Bedienung - Shopware Community | Knowledgebase
danke, prüfen wir.
Unser Speicher bei Profihost wurde kürzlich deutlich überschritten und der Cache wurde sehr groß. Vielleicht hat das system versucht etwas zu speichern und hat Werte überschrieben.
Dann sollte das ebenfalls im Log zu sehen sein. Könnt das ja mal prüfen.
