hallo zusammen, hab seit Installation den unten aufgeführten fehler , erhalte den am Tag 5 mal per Mail am Tag… hat jemand eine Idee was das sein kann oder womit er Zutun hat… 2014-06-09 20:13:17] core.ERROR: exception 'Zend\_Db\_Adapter\_Exception' with message 'LIMIT argument count=0 is not valid' in /virtual/wwwroot/shopware/htdocs/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php:252 Stack trace: #0 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Controllers/Widgets/Emotion.php(524): Zend\_Db\_Adapter\_Pdo\_Mysql-\>limit('? SE...', 0, 0) #1 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Controllers/Widgets/Emotion.php(105): Shopware\_Controllers\_Widgets\_Emotion-\>getProductNewcomer(0, 0, 0) #2 /virtual/wwwroot/shopware/htdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Widgets\_Emotion-\>emotionNewcomerAction() #3 /virtual/wwwroot/shopware/htdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('emotionNewcomer...') #4 /virtual/wwwroot/shopware/htdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #6 /virtual/wwwroot/shopware/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /virtual/wwwroot/shopware/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /virtual/wwwroot/shopware/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #10 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /virtual/wwwroot/shopware/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #12 /virtual/wwwroot/shopware/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /virtual/wwwroot/shopware/htdocs/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main} [] []
Kann es seien das die Einstellung “Anzahl der Artikel, die unter Neuheiten ausgegeben werden” auf 0 steht? Gruß
ja ausschließlich da wir mit Dienstleistungen arbeiten und eigentlich nix auf Lager haben
Das Neuheiten bedeutet nur das Artikel angezeigt werden die in den letzten XX Tagen angelegt wurden. Wenn Du dann bei Anzahl eine 0 Einträgst bekommst Du im SQL ein LIMIT 0 was dann natürlich einen Fehler verursacht
Gruß
