Hallo, ich bekomme seid der Installation alle 1-2 Stunden folgende Fehlermeldung zugeschickt. [2014-04-04 09:44:22] core.ERROR: exception 'Zend\_Db\_Adapter\_Exception' with message 'LIMIT argument count=0 is not valid' in /var/customers/webs/H0/shop/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php:252 Stack trace: #0 /var/customers/webs/H0/shop/engine/Shopware/Controllers/Widgets/Emotion.php(575): Zend\_Db\_Adapter\_Pdo\_Mysql-\>limit('? SE...', 0, 0) #1 /var/customers/webs/H0/shop/engine/Shopware/Controllers/Widgets/Emotion.php(78): Shopware\_Controllers\_Widgets\_Emotion-\>getProductTopSeller(0, 0, 0) #2 /var/customers/webs/H0/shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Widgets\_Emotion-\>emotionTopSellerAction() #3 /var/customers/webs/H0/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('emotionTopSelle...') #4 /var/customers/webs/H0/shop/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 /var/customers/webs/H0/shop/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #6 /var/customers/webs/H0/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /var/customers/webs/H0/shop/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /var/customers/webs/H0/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /var/customers/webs/H0/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/customers/webs/H0/shop/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/customers/webs/H0/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #12 /var/customers/webs/H0/shop/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /var/customers/webs/H0/shop/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main} [] [] Gelegentlich auch diese hier: #0 /var/customers/webs/H0/shop/engine/Shopware/Controllers/Widgets/Emotion.php(524): Zend\_Db\_Adapter\_Pdo\_Mysql-\>limit('? SE...', 0, 0) #1 /var/customers/webs/H0/shop/engine/Shopware/Controllers/Widgets/Emotion.php(105): Shopware\_Controllers\_Widgets\_Emotion-\>getProductNewcomer(0, 0, 0) #2 /var/customers/webs/H0/shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Widgets\_Emotion-\>emotionNewcomerAction() #3 /var/customers/webs/H0/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('emotionNewcomer...') (Rest ist wie oben) Mit meiner begrenzten Erfahrung lese ich daraus, dass es ein Problem damit gibt die Newcommer Produkte auszuwählen bzw. zu nutzen. Ich verstehe nurnicht wieso. Wenn ich meinen Shop aufrufe shop.homwer.com funktioniert alles. Die Meldung scheint auch nicht dann zu kommen wenn jemand die Seite aufruft sondern einfach mal so. Ich würde mich sehr über eine Hilfe freuen. Danke. Philipp
Fehler bekomme ich auch unregelmäßig oft über dem Cronjob wer kann mehr sagen?
