\> core.ERROR: exception 'Zend\_Db\_Adapter\_Exception' with message 'LIMIT argument count=0 is not valid' in /www/htdocs/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php:252 \> Stack trace: \> #0 /www/htdocs/engine/Shopware/Controllers/Widgets/Emotion.php(524): Zend\_Db\_Adapter\_Pdo\_Mysql-\>limit('? SE...', 0, 0) \> #1 /www/htdocs/engine/Shopware/Controllers/Widgets/Emotion.php(105): Shopware\_Controllers\_Widgets\_Emotion-\>getProductNewcomer(0, 0, 0) \> #2 /www/htdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Widgets\_Emotion-\>emotionNewcomerAction() \> #3 /www/htdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('emotionNewcomer...') \> #4 /www/htdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) \> #5 /www/htdocs/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() \> #6 /www/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) \> #7 /www/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) \> #8 /www/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) \> #9 /www/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) \> #10 /www/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) \> #11 /www/htdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) \> #12 /www/htdocs/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) \> #13 /www/htdocs/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) \> #14 {main} [] [] Weis jemamand was das zu bedeuten hat ?
Evtl. hilft dieser Beitrag: installation-einstieg-f54/bug-fehler-bei-klick-auf-aktuelles-fehlermeldung-t8413.html
