Fehler bei Lieferschein Erstellung (Shopware 5.5.8)
Hallo Zusammen,
folgende Fehlermeldung bekomme ich beim versuch einen Lieferschein zu erstellen:
InvalidArgumentException: Passed variable is not an array or object in /engine/Shopware/Models/Document/Order.php:614 Stack trace:
#0 /engine/Shopware/Models/Document/Order.php(614): ArrayObject->__construct(false, 2)
#1 /engine/Shopware/Models/Document/Order.php(197): Shopware_Models_Document_Order->getBilling()
#2 (internal function): Shopware_Models_Document_Order->__construct(848, Array)
#3 /engine/Library/Enlight/Class.php(188): ReflectionClass->newInstanceArgs(Array)
#4 /engine/Shopware/Components/Document.php(176): Enlight_Class::Instance(‚Shopware_Proxie…‘, Array)
#5 /engine/Shopware/Controllers/Backend/Order.php(1834): Shopware_Components_Document::initDocument(848, 2, Array)
#6 /engine/Shopware/Controllers/Backend/Order.php(1133): Shopware_Controllers_Backend_Order->createDocument(848, 2)
#7 /engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Backend_Order->createDocumentAction()
#8 /engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch(‚createDocumentA…‘)
#9 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#10 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#11 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /home/cubtpggx/www.cube-biotech.com/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
Die Datensätze in der Datenbank sehen eigentlich ganz normal aus.
Kann mir hier einer weiterhelfen ?
Klingt aber eher nach einem fehlerhaften Eintrag in der s_order_billingaddress
