seit dem Update auf 5.4.4 kann ich im Backend keine Dokumente mehr erstellen. Folgendes kommt wenn ich auf Vorschau gehe…
Passed variable is not an array or object, using empty array instead in engine/Shopware/Models/Document/Order.php on line 565
Stack trace:
#0 engine/Shopware/Models/Document/Order.php(565): ArrayObject-\>\_\_construct(false, 2) #1 engine/Shopware/Models/Document/Order.php(193): Shopware\_Models\_Document\_Order-\>getBilling() #2 [internal function]: Shopware\_Models\_Document\_Order-\>\_\_construct('91', Array) #3 engine/Library/Enlight/Class.php(188): ReflectionClass-\>newInstanceArgs(Array) #4 engine/Shopware/Components/Document.php(169): Enlight\_Class::Instance('Shopware\_Models...', Array) #5 engine/Shopware/Controllers/Backend/Order.php(1587): Shopware\_Components\_Document::initDocument('91', '1', Array) #6 engine/Shopware/Controllers/Backend/Order.php(910): Shopware\_Controllers\_Backend\_Order-\>createDocument('91', '1') #7 engine/Library/Enlight/Controller/Action.php(193): Shopware\_Controllers\_Backend\_Order-\>createDocumentAction() #8 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispatch('createDocumentA...') #9 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 engine/Shopware/Kernel.php(215): Enlight\_Controller\_Front-\>dispatch() #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main}
kann mir da jemand weiterhelfen? Bin grad etwas ratlos… is da was beim Update schief gegangen?
LG
