Wir bekommen nach dem Update auf 5.7.3 einen Fatal error:
Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\InvalidArgumentException: The "modules" service is private, you cannot replace it. in /home/…./…/Test/vendor/symfony/dependency-injection/Container.php:172 Stack trace: #0 /home/…./…/Test/engine/Shopware/Components/DependencyInjection/Container.php(60): Symfony\Component\DependencyInjection\Container->set() #1 /home/…/…/Test/engine/Shopware/Plugins/Default/Core/System/Bootstrap.php(154): Shopware\Components\DependencyInjection\Container->set() #2 /home/…/…/Test/engine/Library/Enlight/Event/Handler/Plugin.php(155): Shopware_Plugins_Core_System_Bootstrap::onInitResourceModules() #3 /home/…/…/Test/engine/Library/Enlight/Event/EventManager.php(245): Enlight_Event_Handler_Plugin->execute() #4 /home/…/…/Test/engine/Shopware/Components/DependencyInjection/Container.php(194): Enlight_Event_EventManager->notifyUntil() #5 /home/livqmggh/bigb in /home/…/…/Test/vendor/symfony/dependency-injection/Container.php on line 172
Kann jemand erkennen woran das liegt
Beste Grüße
