Fehler nach Update auf 5.7.3
nach dem Update auf 5.7.3 sind Backend und Frontend nicht erreichbar, der Wartungsmodus wird angezeigt. Ich habe alle fremden Plugins in der DB deaktiviert.
Der Cache war leer, da gabs nichts zu löschen.
Fehlermeldung:
> # Slim Application Error
> The application could not run because of the following error:
> ## Details
> **Type:** Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException
> **Message:** The service "mopt_wunschpaket.mail_formatter.html" has a dependency on a non-existent service "TemplateMail".
> **File:** /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php
> **Line:** 86
> ## Trace
> #0 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(82): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Object(Symfony\Component\DependencyInjection\Reference), false)
> #1 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Array, false)
> #2 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(91): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Array)
> #3 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Object(Symfony\Component\DependencyInjection\Definition), true)
> #4 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(82): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Object(Symfony\Component\DependencyInjection\Definition), true)
> #5 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Array, true)
> #6 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(46): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Array, true)
> #7 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(40): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
> #8 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/Compiler.php(94): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
> #9 /var/www/web29558275/html/vendor/symfony/dependency-injection/ContainerBuilder.php(762): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
> #10 /var/www/web29558275/html/engine/Shopware/Kernel.php(552): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
> #11 /var/www/web29558275/html/engine/Shopware/Kernel.php(244): Shopware\Kernel->initializeContainer()
> #12 /var/www/web29558275/html/recovery/update/src/DependencyInjection/Container.php(177): Shopware\Kernel->boot()
> #13 /var/www/web29558275/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container))
> #14 /var/www/web29558275/html/recovery/update/src/DependencyInjection/Container.php(186): Pimple\Container->offsetGet('shopware.contai...')
> #15 /var/www/web29558275/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container))
> #16 /var/www/web29558275/html/recovery/common/src/DependencyInjection/Container.php(71): Pimple\Container->offsetGet('shopware.theme_...')
> #17 /var/www/web29558275/html/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get('shopware.theme_...')
> #18 [internal function]: {closure}()
> #19 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
> #20 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
> #21 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
> #22 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
> #23 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
> #24 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
> #25 /var/www/web29558275/html/recovery/update/index.php(57): Slim\Slim->run()
> #26 {main}
Hat jemand eine Idee, wie ich den Shop wieder zum Laufen bringe?
Vielen Dank!
Zu dem Fehler gibts hier im Forum schon einen Eintrag. Es ist das Wunschpaket Plugin.
Nach dem korrekten deaktivieren des Plugin sollte es eigentlich wieder funktionieren.
Der Fehlermeldung nach wie das Plugin noch immer geladen.
