Fehlermeldung:
Slim Application Error
Type: Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException
Message: The service „mopt_wunschpaket.mail_formatter.html“ has a dependency on a non-existent service „TemplateMail“.
File: /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php
Line: 86
Trace
#0 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(82): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Object(Symfony\Component\DependencyInjection\Reference), false)
#1 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Array, false)
#2 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(91): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Array)
#3 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Object(Symfony\Component\DependencyInjection\Definition), true)
#4 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(82): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Object(Symfony\Component\DependencyInjection\Definition), true)
#5 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(49): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->processValue(Array, true)
#6 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/AbstractRecursivePass.php(46): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->processValue(Array, true)
#7 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php(40): Symfony\Component\DependencyInjection\Compiler\AbstractRecursivePass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#8 /var/www/web29558275/html/vendor/symfony/dependency-injection/Compiler/Compiler.php(94): Symfony\Component\DependencyInjection\Compiler\CheckExceptionOnInvalidReferenceBehaviorPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#9 /var/www/web29558275/html/vendor/symfony/dependency-injection/ContainerBuilder.php(762): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#10 /var/www/web29558275/html/engine/Shopware/Kernel.php(552): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#11 /var/www/web29558275/html/engine/Shopware/Kernel.php(244): Shopware\Kernel->initializeContainer()
#12 /var/www/web29558275/html/recovery/update/src/DependencyInjection/Container.php(177): Shopware\Kernel->boot()
#13 /var/www/web29558275/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))
#14 /var/www/web29558275/html/recovery/update/src/DependencyInjection/Container.php(186): Pimple\Container->offsetGet(‚shopware.contai…‘)
#15 /var/www/web29558275/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))
#16 /var/www/web29558275/html/recovery/common/src/DependencyInjection/Container.php(71): Pimple\Container->offsetGet(‚shopware.theme_…‘)
#17 /var/www/web29558275/html/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get(‚shopware.theme_…‘)
#18 [internal function]: {closure}()
#19 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#20 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#21 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#22 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#23 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#24 /var/www/web29558275/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#25 /var/www/web29558275/html/recovery/update/index.php(57): Slim\Slim->run()
#26 {main}
