Express Kauf doesn't work
Hello everybody, I set up the PayPal via Plugin manager correctly. However, when I tried to complete the buying process via Express Kauf, it shows the followings: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. sSaveRegister #00: Fields are missing NO SESSION-COOKIE - 492aab66a9af0f60cc2854b3bce7512bf79fffe1 - Array ( [0] => billing#2->zipcode ) in engine/core/class/sSystem.php on line 182 Stack trace: #0 engine/core/class/sAdmin.php(1891): sSystem->E_CORE_WARNING(‘sSaveRegister #…’, ‘Fields are miss…’) #1 Shopware/Plugins/Default/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(542): sAdmin->sSaveRegister() #2 Shopware/Plugins/Default/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(300): Shopware_Controllers_Frontend_PaymentPaypal->createAccount(Array) #3 Enlight/Controller/Action.php(148): Shopware_Controllers_Frontend_PaymentPaypal->returnAction() #4 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‘returnAction’) #5 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #6 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #7 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 Shopware/Components/HttpCache/AppCache.php(234): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(403): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(303): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #11 Shopware/Components/HttpCache/AppCache.php(158): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #12 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #13 Shopware/Components/HttpCache/AppCache.php(110): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #15 Enlight/Application.php(192): Shopware_Bootstrap->run() #16 shopware.php(83): Enlight_Application->run() #17 {main} Are there anyone can help? Thanks in advance.
