Error-Log
ich habe vorab die Datenbank mit der Kollation utf8_unicode_ci aufgesetzt.
Die Installationsroutine ist bis fertigstellen gekommen.
Dann kam ein interner Server-Error.
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, service@webmailer.de and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Innerhalb der Installationsroutine  via Installer folgende Error-Logs beim Provi:
12.01.2017 14:49:20 test-content.de [client 89.16.22.0] Premature end of script headers: index.php, referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:51:42 test-content.de [client 89.16.22.0] Premature end of script headers: index.php, referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] RuntimeException: Identifier DB not initialized yet in /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/install/src/ContainerProvider.php:163, referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] Stack trace:, referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #0 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install\{closure}(Object(Pimple\Container)), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #1 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/install/src/ContainerProvider.php(146): Pimple\Container->offsetGet(‚db‘), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #2 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install\{closure}(Object(Pimple\Container)), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #3 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/install/src/app.php(439): Pimple\Container->offsetGet(‚theme.service‘), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #4 [internal function]: {closure}(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #5 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #6 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #7 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #8 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #9 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #10 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #11 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/install/index.php(74): Slim\Slim->run(), referer: http://test-content.de/shopware/recovery/install/index.php/configuration/ 12.01.2017 14:52:12 test-content.de [client 89.16.22.0] #12 {main}, referer: http://test-content.de/shopware/recovery/install/index.php/configuration/
Dazu noch folgende Frontendausgabe:
Slim Application Error
Type:  RuntimeException
Message:  Identifier DB not initialized yet
File:  /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/install/src/ContainerProvider.php
Line:  163
Trace
#0 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#2 /mnt/webu/d1/98/56814398/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#12 {main}
Der Installer hat on top noch folgendes Systemproblem ausgegeben:
Hat jemand die gleichen bzw. ähnliche Installationsprobleme gehabt?
Hast du das Zip denn direkt auf dem Server entpackt?
Häufig fehlen einfach Dateien durch den Upload.
Hi, super lieben Dank für deine Antwort.
Also ich habe die .zip (hab sie umbenannt ) auf dem Sever via .php
   $zip = new ZipArchive;
   $res = $zip->open('setup.zip');
   if ($res === TRUE) {
      $zip->extractTo('./');
      $zip->close();
      echo 'Das Entpacken war erfolgreich';
   } else {
      echo 'Fehler beim Entpacken!';
entpackt, d.h. ich darf von einer Vollständigkeit ausgehen.
Ich telefoniere morgen mit dem Provi bezüglich des Screenshots weiter oben (Systemvorrausetzungen).
Den Punkt mit dem ionCube Loader hab ich gelöst. Ist jetzt Version 6.0 drauf.
Das Auslesen des Speichers bekommt man mit der Löschung folgender Zeile innerhalb der System.xml weg (habe aber die Installation noch nicht finalisiert bis ich alle Systemvoraussetzungen erfüllt habe mach ich nicht weiter):
Der aktuelle Pfad für die  System.xml in Version 5: engine / Shopware / Components / Check / Data
        disk_free_spacecore5 GB1
Mein Problem ist aktuell noch die mod_rewite-Geschichte.
In der .htaccess steht eindeutig:
RewriteEngine on
Daß bei mod_rewrite eine Warnung angezeigt wird, kann vorkommen, da würde ich mir erst einmal keine Gedanken machen. Das Problem, um das Du Dir zuallererst Gedanken machen solltest, ist die zweite Warnung - offensichtlich hast Du keinen freien Speicherplatz mehr, und so kannst Du Shopware natürlich nicht installieren (vermutlich noch nicht einmal komplett entpacken).
www.timmehosting.de
Hi, danke für deinen  Antwort. Ich habe noch gut 30 Gb frei?!
Führe doch mal als root folgendes aus
a2enmod rewrite
/etc/init.d/apache2 restart
Du bist dir sicher, das die Partition (evtl. LVM), auf der Shopware liegt, wirklich noch 30GB freien Speicher hat? Poste mal diese Ausgabe
df -h
