Error in Shop?
Gestern verschwanden einfach ein paar Bilder (mit Links) in den Einkaufswelten - inkl. der Einstellungen des Dreitags Banner Advance. OHNE Errrormeldung.
Heute früh dann diese Error Meldung - mit der ich irgendwie nix anfangen kann… Würde mir jemand sagen, welcher Teil von Shopware betroffen ist?:
ERROR
Message:
 exception 'SmartyException' with message 'unable to write file /../var/cache/production\_201510221322/templates/backend\_de\_DE\_5a6df/f1/7b/46/wrt5742a8cb7e8e37.15415154' in /../engine/Library/Smarty/sysplugins/smarty\_internal\_write\_file.php:48
 Stack trace:
 #0 /../engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(201): Smarty\_Internal\_Write\_File::writeFile('/homepages/12/d...', '<?php /* Smarty...', Object(Enlight_Template_Manager))</pre>
     #1 /../engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource()
     #2 /../engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true)
     #3 /../var/cache/production\_201510221322/templates/backend\_de\_DE\_5a6df/26/db/83/26db832e907ddbf83a80c38665ecdf7b56b7bf56.snippet.index.tpl.php(142): Smarty\_Internal\_Template-\>getSubTemplate('backend/custome...', NULL, 'backend\_de\_DE\_5...', NULL, NULL, Array, 0)
     #4 /../engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_5742a8cb026576\_76465591(Object(Enlight\_Template\_Default))
     #5 /../engine/Library/Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
     #6 /../engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
     #7 /../engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
     #8 /../engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
     #9 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
     #10 /../engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
     #11 /../engine/Library/Enlight/Event/EventManager.php(210): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
     #12 /../engine/Library/Enlight/Controller/Action.php(201): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
     #13 /../engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('loadAction')
     #14 /../engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
     #15 /../engine/Shopware/Kernel.php(148): Enlight\_Controller\_Front-\>dispatch()
     #16 /../vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
     #17 /../engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
     #18 /../vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
     #19 /../engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
     #20 /../shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
     #21 {main}
**Time:**
     2016-05-23T08:52:59.565109+0200
**Channel:**
     core
**request:**
     &nbsp;&nbsp;&nbsp; "uri": "/backend/customer/load/?f=m/Customer|m/Billing|m/Shipping|m/Debit|m/PaymentData|m/List|m/Order|m/Chart|m/BillingAttributes|m/ShippingAttributes|m/Attribute|m/Batch|v/detail/Window|v/detail/Base|v/detail/Billing|v/detail/Shipping|v/detail/Debit|v/detail/Comment|v/detail/Additional|v/list/List|v/main/Window|v/order/List|v/order/Chart|store/Detail|store/List|store/Orders|store/Chart|store/Batch|c/Main|c/List|c/Detail|c/Order&no-cache=1463986368+1+1",
     &nbsp;&nbsp;&nbsp; "method": "GET",
     &nbsp;&nbsp;&nbsp; "query": {
     &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "f": "m/Customer|m/Billing|m/Shipping|m/Debit|m/PaymentData|m/List|m/Order|m/Chart|m/BillingAttributes|m/ShippingAttributes|m/Attribute|m/Batch|v/detail/Window|v/detail/Base|v/detail/Billing|v/detail/Shipping|v/detail/Debit|v/detail/Comment|v/detail/Additional|v/list/List|v/main/Window|v/order/List|v/order/Chart|store/Detail|store/List|store/Orders|store/Chart|store/Batch|c/Main|c/List|c/Detail|c/Order",
     &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "no-cache": "1463986368 1 1",
     &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "module": "backend",
     &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "controller": "customer",
     &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "action": "load"
     &nbsp;&nbsp;&nbsp; },
     &nbsp;&nbsp;&nbsp; "post": []
**session:**
     &nbsp;&nbsp;&nbsp; "userId": "XX",
     &nbsp;&nbsp;&nbsp; "roleId": "1"
**shop:**
     No shop data available
Ich würde mal bei
anfangen und gucken ob das Verzeichnis (inkl. erwartetem Inhalt) existiert und ob die Rechte passen.
Alternativ gleich noch schauen ob genügen Speicherplatz frei ist.
mfg Matthias
Danke für Eure Tipps!
Leider hat das nichts geholfen.
  • Platz ist noch ausreichend
-die ORdner ab /…/f1/ fehlten. Ein Einrichten der Ordnerstruktur brachte keine Änderung.
Wenn man wenigstens wüßte, welches Plugin da betroffen ist…
Okay, Problem gelöst.
Es war ein veraltetes Plugin von Shopware! (Customer Import/Export)
