Error 500 nach update 6.4
Hallo Freunde,
nach dem Update eines Webshops von 6.3.5.3 auf 6.4 erhalte ich einen Fehler 500. Könnten Sie mir bitte auf meinem Weg helfen?
Dies stammt aus dem Log:
[2021-05-30 13:25:12] php.CRITICAL: Fatal Error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16777224 bytes) {"exception":"[object] (Symfony\\Component\\ErrorHandler\\Error\\OutOfMemoryError(code: 0): Error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16777224 bytes) at /home/mydomain/domains/domain.de/public_html/vendor/sabberworm/php-css-parser/lib/Sabberworm/CSS/Parsing/ParserState.php:285)"} []
[2021-05-30 13:31:05] php.CRITICAL: Uncaught Error: Too few arguments to function Swag\PayPal\Util\Lifecycle\Update::__construct(), 5 passed in /home/mydomain/domains/domain.de/public_html/custom/plugins/SwagPayPal/src/SwagPayPal.php on line 166 and exactly 8 expected {„exception“:"[object] (ArgumentCountError(code: 0): Too few arguments to function Swag\PayPal\Util\Lifecycle\Update::__construct(), 5 passed in /home/mydomain/domains/domain.de/public_html/custom/plugins/SwagPayPal/src/SwagPayPal.php on line 166 and exactly 8 expected at /home/mydomain/domains/domain.de/public_html/custom/plugins/SwagPayPal/src/Util/Lifecycle/Update.php:71)"}
[2021-05-30 13:35:34] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: „No route found for „GET /dealers“ (from „https://domain.de/public/")" at /home/mydomain/domains/domain.de/public_html/vendor/symfony/http-kernel/EventListener/RouterListener.php line 136 {„exception“:“[object] (Symfony\Component\HttpKernel\Exception\NotFoundHttpException(code: 0): No route found for „GET /dealers“ (from „https://domain.de/public/“) at /home/mydomain/domains/domain.de/public_html/vendor/symfony/http-kernel/EventListener/RouterListener.php:136, Symfony\Component\Routing\Exception\ResourceNotFoundException(code: 0): No routes found for „/dealers/“. at /home/mydomain/domains/domain.de/public_html/vendor/symfony/routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)“}
Vielen dank im Vorraus!
Nick
Kommst du noch ins Backend und könntest du mal bitte versuchen, das PayPal Plugin zu deaktivieren?
Leider funktioniert die Backend Zugriffe auch nicht. Kann ich den manuell deaktivieren?
Ja klar, über die Datenbank in der Tabelle plugin den Wert active auf 0 setzen.
Jetzt offnët sich wieder die Seite.
Aber es fehtl noch am Backend.
Ich kann gerade einloggen, aber es gibt dann einem Blank Page und logt sich dann wieder automatisch aus.
Welche Fehlermeldung erhältst du jetzt?
Leider gar keine!
Wo kann ich die fehler meldung sehen?
In der Logdatei, schau‘ mal im Verzeichnis /var/log/ auf dem Server.
Wie wurde dieses Problem am Ende gelöst? Stehe aktuell vor dem selben Problem seit dem Update auf 6.4.11.1
Bei dem Update gab es bei mir das selbe Problem.
Backend geht bei mir.
Deaktiviere alle Plugins. Dann sollte der Shop erreichbar sein.
Danach aktivierst du nacheinander die Plugins. Bei mir war es das Sicherheitsplugin.
