error 500 / how install manually?
Hello,
during the installation with one file installer, I get the error 500 from the server (probably because of some values in .htaces, but when I try to change them manually, installer overwrites that again or shows an error that it cannot write during unzipping when I try to edit .htacces and change its CHMOD)
Is there a way how to install shopware manually? I mean edit the config file wit database names/password and run it without using the installer?
Danke!
You always need to run the installer as the database has to be imported and modified to meet your needs.
Please check the error log of your server and post the exact error message to find out what triggered that 500 error.
Regards
