Hallo
ich habe eben das Plugin “Amazon Pay” installiert und ab diesen Moment habe ich keinen Zugriff mehr auf das Backend.
Es kommt nur die Fehlermeldung und ich kann nichts machen.
Was kann ich tun?
Plugin “Auth” not found failure in engine/Library/Enlight/Plugin/PluginCollection.php on line 117
Stack trace:
#0 engine/Library/Enlight/Plugin/Namespace/Config.php(83): Enlight\_Plugin\_PluginCollection-\>load('Auth', true) #1 engine/Library/Enlight/Plugin/PluginCollection.php(97): Enlight\_Plugin\_Namespace\_Config-\>load('Auth', true) #2 engine/Library/Enlight/Plugin/PluginCollection.php(131): Enlight\_Plugin\_PluginCollection-\>get('Auth', true) #3 engine/Shopware/Controllers/Backend/Index.php(48): Enlight\_Plugin\_PluginCollection-\>\_\_call('Auth', Array) #4 engine/Shopware/Controllers/Backend/Index.php(48): Shopware\_Components\_Plugin\_Namespace-\>Auth() #5 engine/Library/Enlight/Class.php(74): Shopware\_Controllers\_Backend\_Index-\>init() #6 engine/Library/Enlight/Controller/Action.php(101): Enlight\_Class-\>\_\_construct() #7 engine/Library/Enlight/Controller/Dispatcher/Default.php(504): Enlight\_Controller\_Action-\>\_\_construct(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #8 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #9 engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\>dispatch() #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #14 shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main}
