Hallo liebe Wissenden,
nach dem updaten eines Plugins kann ich mich nicht mehr im Backend einloggen. Zuerst erschien beim Aufrufen des Backends folgende Meldung:
Plugin „Auth“ not found failure in engine/Library/Enlight/Plugin/PluginCollection.php on line 117
Stack trace:
#0 engine/Library/Enlight/Plugin/Namespace/Config.php(83): Enlight_Plugin_PluginCollection->load(‚Auth‘, true)
#1 engine/Library/Enlight/Plugin/PluginCollection.php(97): Enlight_Plugin_Namespace_Config->load(‚Auth‘, true)
#2 engine/Library/Enlight/Plugin/PluginCollection.php(131): Enlight_Plugin_PluginCollection->get(‚Auth‘, true)
#3 engine/Shopware/Controllers/Backend/Index.php(48): Enlight_Plugin_PluginCollection->__call(‚Auth‘, Array)
#4 engine/Shopware/Controllers/Backend/Index.php(48): Shopware_Components_Plugin_Namespace->Auth()
#5 engine/Library/Enlight/Class.php(74): Shopware_Controllers_Backend_Index->init()
#6 engine/Library/Enlight/Controller/Action.php(101): Enlight_Class->__construct()
#7 engine/Library/Enlight/Controller/Dispatcher/Default.php(504): Enlight_Controller_Action->__construct(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#8 engine/Library/Enlight/Controller/Front.php(226): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 engine/Shopware/Kernel.php(176): Enlight_Controller_Front->dispatch()
#10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#14 shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
Wofaufhin ich, nach einigem Suchen, auf diese Diskussion gestossen bin: https://forum.shopware.com/discussion/38945/brauche-dringend-hilfe-shop-down. Nachdem ich also die DB geprüft habe und die fehlenden Einträge wiederhergestellt habe(händisch), kann ich mich leider immer noch nicht im Backend Anmelden. Zwar wird nun die Seite mit dem Hintergrund geladen, aber das Anmeldeformular taucht nicht auf.
Weitere Dinge die ich seit dem getestet habe:
- das betreffende Plugin ausgeschaltet (über die DB)
- das Debug Plugin ausgeschaltet (ebenfalls über DB)
- die Rechte der Dateien geprüft(per FTP, da ich leider keinen SSH Zugang bekomme).
Zwar sitzt der Programmierer des Plugins auch schon an der Sache, allerdings brauche ich die Möglichkeit ins Backend zu kommen.
Das Backup einspielen ist leider nur meine letzte Möglichkeit, da das Backup schon 2 Monate alt ist.
Danke schon mal für die Hilfe.
LG Anna
