Ich kann keine Themes weder responsive noch irgendwelche älteren Themes ändern vermutlich hängt es damit zusammen :
Image thumbnailsAnchor link for: image thumbnails
The new Responsive theme requires different thumbnail sizes for images. It also supports high DPI thumbnails, if available, to improve the end user’s experience on devices with high pixel density. As such, you should:
For each of the following albums, set the following thumbnail sizes. Keep in mind that any other custom thumbnail sizes you might want to have should appear after these, not before:
AlbumThumbnail sizesEinkaufswelten800x800 1280x1280 1920x1920Banner800x800 1280x1280 1920x1920Artikel200x200 600x600 1280x1280Blog200x200 600x600 1280x1280
Enable High DPI thumbnail generation for all albums that have thumbnail generation enabled.
Regenerate the thumbnails. We recommend using the
sw:thumbnail:generateCLI command for this.
Check your emotion world pages, particularly those depending on thumbnails from the above albums.
As you changed the article thumbnails settings, other parts of your system might also need to be reconfigured to function properly:
- Product export feeds
- Email templates, header and footer
Kann mir jemand bei der umstellung helfen ?
