Belegerstellung funktioniert nicht mehr: Unable to load template snippet 'widgets/checkout/info.tpl
Seit dem 31.07. können wir keine Belege (Lieferschein/Rechnung) mehr manuell erstellen. Folgende Fehlermeldung wird ausgeworfen. Kann da jemand etwas mit anfangen?
CRITICAL
Message:
Unable to load template snippet 'widgets/checkout/info.tpl'
Time:
2020-08-03T10:37:47.052958+0200
Channel:
core
request:
"uri": "/backend/Order/createDocument/targetField/documents?_dc=1596443866244",
"method": "POST",
"query": {
"_dc": "1596443866244",
"module": "backend",
"controller": "Order",
"action": "createDocument",
"targetField": "documents"
"post": {
"orderId": 17300,
"deliveryDate": "",
"displayDate": "03.08.2020",
"vatId": "",
"invoiceNumber": "",
"documentType": 2,
"docComment": "",
"taxFree": 0
session:
No session data available
shopId:
1
shopName:
Shopname
ERROR
Message:
SmartyException: Unable to load template snippet 'widgets/checkout/info.tpl' in /var/www/vhosts/domain.de/httpdocs/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127
Stack trace:
#0 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/View/Default.php(295): Smarty_Internal_TemplateBase->fetch()
#1 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default))
#2 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#3 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#4 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Event/Handler/Default.php(87): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#6 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Action.php(234): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#7 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch('infoAction')
#8 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Template/Plugins/function.action.php(91): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 /var/www/vhosts/domain.de/httpdocs/var/cache/production_202005221140/templates/Domain_1/1a/85/48/1a8548d517d44a8b190022dcbc80ac9dfa11e31e.snippet.index_ls.tpl.php(2118): smarty_function_action(Array, Object(Enlight_Template_Default))
#10 /var/www/vhosts/domain.de/httpdocs/var/cache/production_202005221140/templates/Domain_1/1a/85/48/1a8548d517d44a8b190022dcbc80ac9dfa11e31e.snippet.index_ls.tpl.php(699): content_5f27ccdab50c86_26839955(Object(Enlight_Template_Default))
#11 /var/www/vhosts/domain.de/httpdocs/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_5f27ccdb0073c5_63823807(Object(Enlight_Template_Default))
#12 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Components/Document.php(270): Smarty_Internal_TemplateBase->fetch('documents/index...', NULL)
#13 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Controllers/Backend/Order.php(1874): Shopware_Components_Document->render()
#14 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Controllers/Backend/Order.php(1164): Shopware_Controllers_Backend_Order->createDocument(17300, 2)
#15 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Backend_Order->createDocumentAction()
#16 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch('createDocumentA...')
#17 /var/www/vhosts/domain.de/httpdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#18 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch()
#19 /var/www/vhosts/domain.de/httpdocs/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#20 /var/www/vhosts/domain.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#21 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#22 /var/www/vhosts/domain.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#23 /var/www/vhosts/domain.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#24 /var/www/vhosts/domain.de/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#25 {main}
Time:
2020-08-03T10:37:47.053391+0200
Channel:
core
request:
"method": "POST",
"query": {
"post": {
"orderId": 17300,
"deliveryDate": "",
"vatId": "",
"documentType": 2,
"docComment": "",
"taxFree": 0
session:
shopId:
1
