Guten Tag, Seit dem heutigen Patch funktioniert der Login in den Adminbereich nicht mehr, cache habe ich bereits geleert: [code]
Class Shopware\Models\User\User is not a valid entity or mapped super class. in Doctrine/ORM/Mapping/MappingException.php on line 147
Stack trace:
#0 Doctrine/ORM/Mapping/Driver/AnnotationDriver.php(166): Doctrine\ORM\Mapping\MappingException::classIsNotAValidEntityOrMappedSuperClass('Shopware\Models...') #1 Doctrine/ORM/Mapping/Driver/DriverChain.php(75): Doctrine\ORM\Mapping\Driver\AnnotationDriver-\>loadMetadataForClass('Shopware\Models...', Object(Doctrine\ORM\Mapping\ClassMetadata)) #2 Doctrine/ORM/Mapping/ClassMetadataFactory.php(293): Doctrine\ORM\Mapping\Driver\DriverChain-\>loadMetadataForClass('Shopware\Models...', Object(Doctrine\ORM\Mapping\ClassMetadata)) #3 Doctrine/ORM/Mapping/ClassMetadataFactory.php(178): Doctrine\ORM\Mapping\ClassMetadataFactory-\>loadMetadata('Shopware\Models...') #4 Doctrine/ORM/EntityManager.php(269): Doctrine\ORM\Mapping\ClassMetadataFactory-\>getMetadataFor('Shopware\Models...') #5 Doctrine/ORM/UnitOfWork.php(2373): Doctrine\ORM\EntityManager-\>getClassMetadata('Shopware\Models...') #6 Doctrine/ORM/Internal/Hydration/SimpleObjectHydrator.php(131): Doctrine\ORM\UnitOfWork-\>createEntity('Shopware\Models...', Array, Array) #7 Doctrine/ORM/Internal/Hydration/SimpleObjectHydrator.php(50): Doctrine\ORM\Internal\Hydration\SimpleObjectHydrator-\>hydrateRowData(Array, Array, Array) #8 Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(106): Doctrine\ORM\Internal\Hydration\SimpleObjectHydrator-\>hydrateAllData() #9 Doctrine/ORM/Persisters/BasicEntityPersister.php(738): Doctrine\ORM\Internal\Hydration\AbstractHydrator-\>hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array) #10 Doctrine/ORM/EntityRepository.php(179): Doctrine\ORM\Persisters\BasicEntityPersister-\>loadAll(Array, NULL, NULL, NULL) #11 Doctrine/ORM/EntityRepository.php(165): Doctrine\ORM\EntityRepository-\>findBy(Array) #12 Shopware/Components/Acl.php(84): Doctrine\ORM\EntityRepository-\>findAll() #13 Shopware/Components/Acl.php(53): Shopware\_Components\_Acl-\>initAclRoles() #14 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(485): Shopware\_Components\_Acl-\>initShopwareAclTree(Object(Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql)) #15 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAcl(Object(Enlight\_Event\_EventArgs)) #16 Enlight/Event/EventManager.php(203): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #17 Enlight/Bootstrap.php(300): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #18 Enlight/Bootstrap.php(258): Enlight\_Bootstrap-\>loadResource('Acl') #19 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(321): Enlight\_Bootstrap-\>getResource('Acl') #20 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(468): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #21 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #22 Enlight/Event/EventManager.php(203): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #23 Enlight/Bootstrap.php(300): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #24 Enlight/Bootstrap.php(232): Enlight\_Bootstrap-\>loadResource('Auth') #25 Enlight/Application.php(519): Enlight\_Bootstrap-\>hasResource('Auth') #26 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(230): Enlight\_Application-\>\_\_call('Auth', Array) #27 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(230): Shopware-\>Auth() #28 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(211): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>checkAuth() #29 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onPreDispatchBackend(Object(Enlight\_Event\_EventArgs)) #30 Enlight/Event/EventManager.php(165): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #31 Enlight/Controller/Action.php(128): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Array) #32 Enlight/Controller/Dispatcher/Default.php(521): Enlight\_Controller\_Action-\>dispatch('loadAction') #33 Enlight/Controller/Front.php(214): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #34 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight\_Controller\_Front-\>dispatch() #35 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #36 Shopware/Components/HttpCache/AppCache.php(242): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #37 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #38 Shopware/Components/HttpCache/AppCache.php(86): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #39 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #40 Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #41 shopware.php(83): Enlight\_Application-\>run() #42 {main}
[/code] Hilfe? Was ist zu tun? Danke!
