Backend Fehler nach Installation von ionCube Loder
Hallo, habe auf dem Server den ionCube Loader installiert um kommerzielle Plugins zu installieren. Das Frontend läuft soweit. Wenn ich allerdings in das Backend einsteigen will, bekomme ich folgende Fehlermeldung: [code]
Zend_Session::start() - /home/.sites/28/site1/web/shopware/engine/Library/Zend/Db/Table/Abstract.php(Line:839): Error #1024 Failed saving metadata to metadataCache in Zend/Session.php on line 506
Stack trace:
#0 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(432): Zend\_Session::start(Array) #1 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceBackendSession(Object(Enlight\_Event\_EventArgs)) #2 Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #3 Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #4 Shopware/Bootstrap.php(168): Shopware\Components\DependencyInjection\Container-\>load('BackendSession') #5 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(467): Shopware\_Bootstrap-\>loadResource('BackendSession') #6 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #7 Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #8 Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #9 Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #10 Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #11 Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #12 Shopware/Controllers/Backend/ExtJs.php(162): Enlight\_Application-\>\_\_call('Auth', Array) #13 Shopware/Controllers/Backend/ExtJs.php(162): Shopware-\>Auth() #14 Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #15 Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('indexAction') #16 Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #17 Shopware/Kernel.php(145): Enlight\_Controller\_Front-\>dispatch() #18 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #19 Shopware/Components/HttpCache/AppCache.php(257): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #20 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(242): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #21 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #22 shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #23 {main}
[/code] Ist dies ein Rechteproblem? Die Rechte 777 im Ordner engine und allen Unterordnern sind gesetzt.
