Hallo Gemeinde,
wir haben mehrere Fehler / Probleme beim Update auf Shopware 5.2:
Problem 1:
Wenn ich mich als Kunde im Frontend einloggen will kommt nach dem Login folgende Fehlermeldung:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'ub.customernumber' in 'field list' in engine/Library/Zend/Db/Statement/Pdo.php on line 234
Stack trace:
#0 engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array)
#1 engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array)
#2 engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query('\n SELECT...', Array)
#3 engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend_Db_Adapter_Pdo_Abstract->query('\n SELECT...', Array)
#4 engine/Library/Zend/Db/Adapter/Abstract.php(756): Enlight_Components_Db_Adapter_Pdo_Mysql->query('\n SELECT...', Array)
#5 engine/Shopware/Plugins/Community/Frontend/SwagPromotion/Components/DataProvider/CustomerDataProvider.php(132): Zend_Db_Adapter_Abstract->fetchRow()
#6 engine/Shopware/Plugins/Community/Frontend/SwagPromotion/Components/DataProvider/CustomerDataProvider.php(62): Shopware\SwagPromotion\Components\DataProvider\CustomerDataProvider->getCustomerData()
#7 engine/Shopware/Plugins/Community/Frontend/SwagPromotion/Components/BasketContextBuilder.php(114): Shopware\SwagPromotion\Components\DataProvider\CustomerDataProvider->get()
#8 engine/Shopware/Plugins/Community/Frontend/SwagPromotion/Components/Promotion/Selector/PromotionSelector.php(94): Shopware\SwagPromotion\Components\BasketContextBuilder->getCustomerData()
#9 engine/Shopware/Plugins/Community/Frontend/SwagPromotion/Subscriber/PromotionSubscriber.php(123): Shopware\SwagPromotion\Components\Promotion\Selector\PromotionSelector->apply()
#10 [internal function]: Shopware\SwagPromotion\Subscriber\PromotionSubscriber->afterGetBasket(Object(Enlight_Hook_HookArgs))
#11 engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Hook_HookArgs))
#12 engine/Library/Enlight/Event/EventManager.php(296): Enlight_Event_Handler_Default->execute(Object(Enlight_Hook_HookArgs))
#13 engine/Library/Enlight/Hook/HookManager.php(191): Enlight_Event_EventManager->filter('sBasket::sGetBa...', Array, Object(Enlight_Hook_HookArgs))
#14 var/cache/production_201608150941/proxies/sBasketProxy.php(25): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_sBasketProxy), 'sGetBasket', Array)
#15 engine/Shopware/Core/sBasket.php(1713): Shopware_Proxies_sBasketProxy->sGetBasket()
#16 engine/Shopware/Controllers/Frontend/Account.php(547): sBasket->sRefreshBasket()
#17 engine/Shopware/Controllers/Frontend/Account.php(252): Shopware_Controllers_Frontend_Account->refreshBasket()
#18 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Account->loginAction()
#19 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('loginAction')
#20 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#21 engine/Shopware/Kernel.php(176): Enlight_Controller_Front->dispatch()
#22 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#23 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#24 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#25 vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#26 engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#27 vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#28 engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#29 shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#30 {main}
Problem 2:
Wir können keine Artikel mehr in den Warenkorb legen. Also es werden schon Artikel in den Warenkorb gelegt, allerdings bleibt nach dem Klick auf „In den Warenkorb legen“ der Ladebalken im rechten Off-Canvas stehen. Klicke ich dann irgendwo anders hin befindet sich der Artikel im Warenkorb.
Kann mir jemand mögliche Fehlerursachen nennen?
Gruß
kweb
