I try use Xdebug(2.3.3/2.4.1) with Shopware, but i get an error (apache2/error.log):
AH00051: child pid 6523 exit signal Segmentation fault (11), possible coredump in /tmp/apache-coredumps
Gdb core:
[New LWP 6394]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/sbin/apache2 -k start'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 xdebug_add_stack_frame (zdata=zdata@entry=0x7f2d185ec6e0, op_array=op_array@entry=0x7f2d1a7131e8, type=type@entry=2) at /tmp/pear/temp/xdebug/xdebug_stack.c:1096
1096 /tmp/pear/temp/xdebug/xdebug_stack.c: No such file or directory.
Do you have any idea? Thanks.
