Warenkorb Endlosschleife
seit heute lässt sich mein Warenkorb nicht mehr aufrufen. Vorab: Plugins wurden keine hochgeladen. Es wurden nur Artikelbeschreibungen geändert.
Folgende Fehlermeldung habe ich erhalten:
 exception 'SmartyException' with message 'Unable to load template snippet 'frontend/plugins/pix\_google\_enhanced\_ecommerce/cart.tpl' in 'frontend/checkout/ajax\_cart.tpl|frontend/imnxxgoogleoptIntegration/imnxxlogointegration.tpl|frontend/amazon\_pay/amazon\_add\_buttons.tpl|frontend/plugins/six\_seotext/index.tpl|frontend/plugins/six\_seotext/sidebar.tpl|frontend/plugins/six\_seotext/footer.tpl'' in /var/www/clients/client1/web4/web/engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php:127
 Stack trace:
 #0 /var/www/clients/client1/web4/web/engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true)
 #1 /var/www/clients/client1/web4/web/var/cache/production\_201704210836/templates/frontend\_AWTheme\_de\_DE\_1\_secure/e9/d9/73/e9d973d8caf0a8bea0cabe433962d829b5d56bb0.snippet.footer.tpl.php(169): Smarty\_Internal\_Template-\>getSubTemplate('frontend/plugin...', NULL, NULL, NULL, NULL, Array, 0)
 #2 /var/www/clients/client1/web4/web/engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_5911dadc536068\_06395518(Object(Enlight\_Template\_Default))
 #3 /var/www/clients/client1/web4/web/engine/Library/Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
 #4 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #5 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #6 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #7 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #8 /var/www/clients/client1/web4/web/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #9 /var/www/clients/client1/web4/web/engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #10 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #11 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('ajaxCartAction')
 #12 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #13 /var/www/clients/client1/web4/web/engine/Shopware/Kernel.php(182): Enlight\_Controller\_Front-\>dispatch()
Kann mir jemand einen Tipp geben was ich mir ansehen könnte um den Fehler zu beheben ? Vielen Dank vorab !
mach mal /pix_google_enhanced_ecommerce aus - das steht ja in der Fehlermeldung.
Eigentlich sagt die erste Zeile auch das was nicht von Plugin “pix_google_enhanced_ecommerce” geladen werden kann. könnte ja nur was mit dem Plugin zu tun haben.
Den kompletten Cache hattest zu ja bestimmt schon geleert und das Themes kompilieren.
Welcher Shopware-Version hast du überhaupt?
Uwe
Es liegt tatsächlich am Plugin. Was ich nicht verstehe, ist dass alles etwa 2 Wochen funktioniert hat und von heute auf morgen dieser Fehler auftrat.
Zudem soll die Pluginversion mit Shopware 5.2.22 kompatibel sein. Mal sehen was der Plugin Anbieter antwortet.
@ Moritz & Uwe…herzlichen Dank für die Mühe sich das mal anzusehen und für den Tipp !
