Sitemap kann nicht erstellt werden // SmartyException: Unable to load template snippet
Hallo seit kurzen wird unsere Sitemap nicht mehr generiert / angezeigt. Der Aufruf erfolgt über
meine-domain.de/sitemap_index.xml
Im Log erhalten wir folgende Meldung:
SmartyException: Unable to load template snippet 'frontend/sitemapindex_xml/index.tpl|frontend/plugins/seo/index.tpl' in /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace:
#0 /engine/Library/Enlight/View/Default.php(300): Smarty_Internal_TemplateBase->fetch()
#1 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#2 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#3 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#4 /engine/Library/Enlight/Event/Handler/Default.php(91): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 /engine/Library/Enlight/Event/EventManager.php(220): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#6 /engine/Library/Enlight/Controller/Action.php(234): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#7 /engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('indexAction')
#8 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#10 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#18 XX/XXX/XXX/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#19 {main}
Kann jemand helfen ?
Habe die Lösung in einen anderen Thema zu PayPal gefunden:
@Webmaster-Oli
Wir haben heute eine neue Version des Plugins herausgebracht, welches die Probleme löst.
@P.Thesing
Gab es das Problem mit der Unterstrich-Validierung nur beim Security-Plugin oder auch im Shopware-Update 5.7.15?
Kann man das Security-Update also bedenkenlos ausführen oder sollte man auch hier besser auf einen entsprechenden Fix warten?
hab das problem auch, seit ich gestern den security patch V 1.1.34 eingespielt habe. Wenn man die Option #26913 in den Plugin Einstellungen deaktiviert funktioniert es wieder. Ist wohl nicht Sinn der Sache, aber temporär wohl ein möglicher Workaround bis ein Fix raus kommt.
Das Update auf 1.1.35 wurde gerade eingespielt. Seit dem läuft es wieder. Danke.
@drakon, das Problem gab es nur im Security-Plugin. Weil wir dort die URL umgeschrieben haben.
