Hi Zusammen, hat jmd. eine Idee was hier das Problem sein könnte, bzw. wie man es lösen könnte? Unsere Einkaufswelten von unserem Sub-Shop werden nichtmehr angezeigt, (naturenpure = hauptshop)
Beste Grüsse, Patrick
Fatal error : Uncaught SmartyException: Unable to load template snippet ‚widgets/error/generic_error.tpl‘ in /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace: #0 /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Enlight/View/Default.php(295): Smarty_Internal_TemplateBase->fetch() #1 /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #2 /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #3 /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Enlight/Event/Handler/Default.php(87): Enlig in /var/www/vhosts/naturenpure.ch/httpdocs/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
