Hallo, habe das Plugin Artikel-upload installiert und funzt eigentlich ganz gut. Nur wenn ich die Bestellung abschließe kommt folgende Fehlermeldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. DirectoryIterator::__construct(/deivcshj/www.deinstempel24.de/shop//shop/files/articleUploads) [directoryiterator.–construct]: failed to open dir: No such file or directory in Shopware/Plugins/Community/Frontend/SwagSimpleUpload/Bootstrap.php on line 488 Stack trace: #0 Shopware/Plugins/Community/Frontend/SwagSimpleUpload/Bootstrap.php(488): DirectoryIterator->__construct(’/deivcshj/www.d…’) #1 Shopware/Plugins/Community/Frontend/SwagSimpleUpload/Bootstrap.php(375): Shopware_Plugins_Frontend_SwagSimpleUpload_Bootstrap->cleanUpUploadDir(Object(Shopware_Models_Plugin_Config)) #2 [internal function]: Shopware_Plugins_Frontend_SwagSimpleUpload_Bootstrap::onOrder(Object(Enlight_Hook_HookArgs)) #3 Enlight/Hook/HookHandler.php(104): call_user_func(‚Shopware_Plugin…‘, Object(Enlight_Hook_HookArgs)) #4 Enlight/Hook/HookManager.php(106): Enlight_Hook_HookHandler->execute(Object(Enlight_Hook_HookArgs)) #5 Shopware/Proxies/sOrderProxy.php(22): Enlight_Hook_HookManager->executeHooks(Object(Enlight_Hook_HookArgs)) #6 Shopware/Controllers/Frontend/Checkout.php(520): Shopware_Proxies_sOrderProxy->sSaveOrder() #7 Shopware/Controllers/Frontend/Checkout.php(197): Shopware_Controllers_Frontend_Checkout->saveOrder() #8 Enlight/Controller/Action.php(70): Shopware_Controllers_Frontend_Checkout->finishAction() #9 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‚finishAction‘) #10 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #11 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch() #12 Enlight/Application.php(86): Shopware_Bootstrap->run() #13 shopware.php(6): Enlight_Application->run() #14 {main} Was könnte dies sein???
Hi, Schau dir mal den Pfad in der Fehlermeldung an: www.deinstempel24.de/shop//shop/files/articleUploads Da ist 2x shop mit Doppelslash drin. Da hast du irgendwo die Angabe des Pfades falsch hinterlegt.
Habe ich im Plugin rausgenommen dann stimmt der pfad… Aber dann habe ich keine Vorschaubilder mehr im Shop. Also an dem kann es nicht liegen. Upload funktioniert ja auch. wenn ich die Seite dann aktualisieren kommt die Vielen Dank Seite!
Hi, der Pfad ist aber defenitiv falsch. Ggf. der Ordner im Plugin selber so eingestellt? Die Meldung sagt ja aus, dass genau das das Problem ist. Dort Ordner darf dort ja nicht doppelt geführt werden mit Doppelslash! Ggf. ist der Pfad auch im Installationspfad fehlerhaft definiert. Das kann ich aber nur vermuten, da die Fehlermeldung den Pfad so anzeigt. Der muss ja irgendwo herkommen
