Hi, jemand eine Idee zu dieser Fehlermeldung (SW 6.5 Update installiert):
Could not execute „composer require“ for plugin "SwagCommercial (shopware/commercial:5.0.0). Output: ./composer.json has been updated Running composer update shopware/commercial --with-dependencies Loading composer repositories with package information Info from https://repo.packagist.org: #StandWithUkraine Updating dependencies Your requirements could not be resolved to an installable set of packages. Problem 1 - Root composer.json requires shopware/commercial, it could not be found in any version, there may be a typo in the package name. Potential causes: - A typo in the package name - The package is not available in a stable-enough version according to your minimum-stability setting see for more details. - It’s a private package and you forgot to add a custom repository to find it Read for further common problems. Installation failed, reverting ./composer.json and ./composer.lock to their original content.
